Yo VIC people, project FATLINE has started
Hey guys,
my car is sleeping at BMT at the moment, waiting for a substantial list of stuff to go on. If any of you are in there in the next week or so, say hi to it, its the silver 33 with a drift wing. The main thead is below, but i've had trouble uploading pics. I will update that thread as I go... :)
http://www.skylinesaustralia.com/forums/sh...&threadid=28349
  • Replies 104
ooooooooooooooooh marcus! so UR ronin!
that was me in there yesterday when u dropped it off.... we dropped off the gfs soarer.
finally put a face to that name :)
well the bodykit n the engine are on their way, as is the turbo, manifold n wastegate... now all i need to do are find an intercooler kit for and RB25, ECU, boost control etc and an exhaust system... and I'll be set...
January sure seems like a good month to be spending hard earned christmas money...
nengun has hks and trust cooler kits for like 1300 delivered... do u need a full ecu or just a management system?
i might end up with a Power FC, might get a datalogit as well and see if I can get some readings out of it. I was looking at a HKS cooler kit, works out to be around 800 bucks, i'll chuck it on the container with my engine n shit on it. I gotta sell my RB20DE too, find sum1 with a n/a silvia or a n/a cefiro... or maybe even a 240z... looks like the ecu and power fc n commander will cost me more than my engine!
Originally posted by Ronin 09
one week boys, and all will be revealed...
i should have some more things to put on tomorrow evening.
I am still having issues uploading pics :D
Can i guess??
Greddy Plenum, Infinity throttle body, AIR cooler???
What about the main go fast bit?? A big ass turbo?
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
