Go for an external pump if possible. Just need to make up a bracket, and a couple of lines and a drive pulley. Going by what youve been saying in the last few threads ive seen, you seem more then capable of doing it all yourself.
I dont believe they would be anymore expensive then any of jap pumps....shit our last 4 stage pump was about 1700. What do the jap ones go for these days?
I dont have a problem going for dry sump besides space, I am really limited, but a close second is that I dont feel with mediocure power I need to resort to dry sump and all the aditional plubing. I am an engineer by trade, I have a few stock RB pumps here, I will do some material testing on the remains of the N1 next week as well as compare it to stock.
Thinking about giving the Nitto a try,
And yes, I do have a crank collar installed.
A thought occured to me when looking at my crank collar.. what is the clearance between the collar and the oil pump drive? would it be better to have something machined to suit the specific oil pump you are going to use so as to get the best fit?
If they were truly that bad there would be threads on all the forums every other week about it now wouldn't there? Sadly that isn't the case.
There is a thread every 6-12months or so, and virtually every one results in owner abuse via rev limiter or a poor motor build.
I don't think anyone is saying that every N1 pump is going to fail, more that the chances of a failure are higher than with other pumps.
As for it being a build problem, that would imply Nissan can't build their own motors.... I'm sure I've posted this before, but this was my N1 pump off an 8,000km old R34 N1 motor that barely ever saw limiter or "hard driving":
To me, that points towards either poor grade materials used in the pump, or Nissan not knowing how to build their own N1 spec motors. I'd say the former is more likely...
I actually think it could be the latter! I've ordered a number of R34 n1 Nur crate motors from nissan japan. all of them I had pulled down at an experienced workshop in japan. 1 was excellent 3 needed work, 1 in particular (farken my one!) was very poor and we actually got money out of nissan JP to pay for the work needed to get it right. some parts of it were excellent, but piston finish was poor for some reason, piston balance was out too (supposed to be hand balanced and the other ones certainly were), crank was perfect, rods were perfect but overall it was a bit of a surprise. the shop I use it japan does it as the basic for any street/track GTR freshen up.
buy new crate motor so you're starting with everything brand new.
pull it apart!
fix what's wrong with it.
port head as desired (depending on use how far you go here)
add metal head gasket to enable it to live with some higher than intended cylinder pressures (don't go crazy, 1.2mm max is needed really)
port out oil returns, add oil feed restrictor.
and then they're good to go.
at the same time generally they add a set of cams and a few other bits as desired but that's the basic idea. and they seem to live pretty well.
having said all that it's quite possible the material varies just like the workmanship...
I hear a rumor you were going to be at the bank tomorrow night.... Not true??
true...im flying up tomm. morning to run the car tomm. night. Flying back the next day.
Edited by DiRTgarage
I have a N1 Pump in my car. Tomei stroker, GT block with GT RS's off the side. Limiter set at 8500 RPM only to not hit it. Always shift no higher then 8000. Motor has so far done 16000 kms. It does have a ATi balancer on it though.... if that helps. Maybe one of the good ones? Knock on wood it doesnt kick the bucket next time i drive it!
I guess its the luck of the draw.
You could bash the limiter all day long for 10 years and not have a problem.
Then again you could have the pump fail with your grandma behind the wheel.
Fingers crossed!
Have a chat to Powertune in NSW about their RB26 oil pump gear sets. Made out of somethin crazy like P20 tool steel or somethin and the same size as a JUN gear set and they can machine the stock housing to suit.
you would actually be suprised to find out what material they are actually made out of. you would then feel pretty bad if u spent the ~550 asking price ;)
I had an N1 pump fail <2000km old
Had new gears machine, apparently by Powertune - fingers crossed
oh, best you dont read my post above :cool:
if your serious and want to talk about dry sump/external pump clearances send me a pm and i'll help you out.
i'm more than happy to help you out without emptying your pockets ;)
lol...$120 return...Jetstar FTW. :D
Virgin hostesses are much better looking though ;)
I bought a stock r33 gtr pump for the 2630 im putting toghether in the hope that it will be stronger than the n1 item. Probably wishful thinking though?
getting offtopic here but u should stick a good condition rb30 pump on it
Ok,
Greddy is available right now ,
Jun is $200us more available 2 weeks leed time
I think the toss up will be nismo and Jun though i havent heard much bad about greddy?
JUN + greddy = same same.
what's involved in doing a pump r and r in an R32 GTR with the engine in? doable within reason? those reimax gears look the goods.
it wouldnt be possible if it needs a collar, even so the subfame would have to be dropped to drop the sump low enough to remove the pump.
im with draino, external or nothin :D
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
