Furthermore everyone should dry sump without question regardless of their needs or requirement as risk is not good.
problem with a dry sump setup is cost - for something decent you are looking at up to 7k
Ofcourse every oil pump is a risk. But we dont log on here to see every couple of months a comment about how my std oil pump just killed my motor, or my (insert brand name here) pump just shat itself...its always the N1 pumps that come up either on here, or in conversation/passing comment or someone at the track blows one up.
Its obvious the risk is higher using one, its virtually the point of this thread. Hearing one bad story should be enough. It was for me, except ive been exposed to multiple, whether on here or at the track. Im sure alot of people who have seen this thread will agree with myself and the others who share the same opinion about N1 pumps.
Its simple. You get whatever puts your mind at ease and fits in with your budget.
Dry sumps all round for everybody.....hooray :P
Edited by r33_racer
guys loosing sleep over the pumps go and buy the reinik (edit reimax... still getting used to name change) gears. they are very highly regarded in japan and folks smarter than me have been using them in aus with great success. they may not be jumping up and down telling everyone about it, but the price is right, they have the research behind them to back up their product and that should be the end of your oil pump problems.
If you're spending 7k on a dry sump setup you're spending too much.
nitto would be my choice, crd has been exposed to all oil pumps available and i trust the opinion of a man who started modifying gtr's when we were all still playing with matchbox cars and smashing them with hammers to simulate an accident
dry sump for me is overkill for a weekend warrior
Where are these available from?
I still think the best fix would be a splined collar/gear.
Cheapest Reimax gear set i can find so far is 670 au + del. through Greenline.
http://www.greenline.jp/catalogue/bproduct...&fromlink=1
It probably is best value for $$$ if you are planning on taking your engine to pieces or in the build stage.
Edited by Alf
Lookin forward to these new gears!
would they work on a stock pump? or does the stock pump not provide enough pressure?
say compared to a n1?
They can be made to suit a stock pump, but these first ones are going to be for the N1 pump.
Pump selection should be left upto the engine builder.
I to had a n1 let go on e and decided to go external pump
i have had no probles since and thrash it of limeter all day at the track and the cost was not to bad
$1000 for peterson single stage pump
$200 for mandrel for the crank
$200 for speedflow fittings
and 1 day in the gargae making a bracket for the pump
This is the way to go imo
That's under valuing it a bit to say the least. Add another $600 and ur closer to the mark you woulda spent. (not saying u didnt spend that but just adding this so everyone doesn't jump to the conclusion it only costs $1400 to do a complete external oil pump setup)
Shane, are there different thickness N1 gears? I remember getting confused when I last looked at the Reimax ones
There are indeed my good friend. So what we'll have to do is the person after a set will have to specify what thickness gears they are after.
Group buy thread here - http://www.skylinesaustralia.com/forums/Sp...ts-t285926.html
Cool, I'll try get my oil pump off this weekend and confirm thickness.
FWIW, here are some parts numbers that I came up with and pricing for an external oil pump kit. I only really needed to find someone to make a bracket for the pump itself, most of the parts are there minus the hosing and belt. Might be a couple of extra fittings required depending on where / how you wanted to mount it.
Some of the prices may have changed since I did it (about 4 months ago)
JWAuto are doing CNC brackets...their work is incredible...the same CNC machinist 888 Racing use. Top shelf stuff. They are doing the brackets in a kit only though...im doing a group buy on them as soon as they are ready. I saw one of their VL CNC'd rocker covers to suit single cam engines running roller rockers...porno! Ill see if i can get a pic.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
