probably a factor....but maybe not the only one in rb blocks.
since they are cast, have a full girdle and the crank is factory forged and nitrided...they are pretty strong compared to many motors despite being a long 6 cylinder. this is supported by the fact they almost never spin main bearings.....
this is what breaks the oil pump.
a good read on whats happening :crankshaft harmonics
That's what said a while ago... It's going on without a doubt.
They are a I4. Not a longer I6.
Taking a wild stab here but a I4 is not going to have the crank movement a I6 has, especially due to weight and so on.
Nor are the forces/pressures there especially if hitting limiters and so on with all that extra spinning around.
And it was met with...
Torsional vibration and harmonics are generaly worse in an I4 due to firing order and cyl sequence, also one of the reasons most I4's have ballance shafts to try help NVH
Large crank movement = toasted bearings, SR20's run main bearings pretty easy if not 100% dead on ballance when running over 400wkw yet dont break oil pumps running a near identical drive setup & dimensions to the RB... Rb on the other hand comes out with bearings looking like brand new yet oil pump is scrap metal, The RB pump is driven not even 3-4mm from No:1 main bearing, pump gets damaged from movement but bearing isnt touched?
There is no way to have rotational vibration / whip without it running out of center.
Yes Rezlo an inline 6 is dynamically balanced, so no issue there.
:D
Time to revisit?
That correlates with the "a good harmonic balancer will save your oil pump" theory i've heard stated on here.
every time theres an oil pump thread i cut and paste this page from ati.. sums it all up. stock balancers wont be suficiant to keep a "stock" oil pump alive, not evan a trust or jun either.
on another note, our race supra (2jz) has a alloy crank pully with zero dampening, looks like a water pump pully.. its not blown the oil pump either. and it hits the limmiter pretty hard. just goes to show how superier the toyota oil pump drive system is..
ive tried to make them put a good balancer on, but with no sucess lol.
Group buy was removed @ the request of the creator.
"Well considering theres a few guys not real confident and wanting to see some testing results, this group buy can be closed for the mean time."
Fair enough too IMO. A G/B that should have started once there was some actual testing for sanity's sake at least. ;)
Whats happeneing with the gears? can't seem to find the group buy- probably blind i'll have another look.
Yes they are still being made. I closed the GB thread to follow the forum rules ;). I'll put up another one when i have some 'testing results'
Anyone have any pics of the inside of the NITTO Pumps ? - I would really like to see what makes it special, other than what is said about it.
I am a little interested now and like many others, I was simply scared into facing the fact that I would have to eventually buy a Tomei Pump for my ongoing build, but if there is an alternative, I am open to reveiwing it.
Thanks,
Allan
Thanks,
Allan
i can send you a photo of the nitto pump that ate cast iron if you like...your e-mail address?
[email protected]
Thanks.
Although THIS does interest me, I am still waiting patiently for the AUS 'Tomei' replacement :)
So to whoever is doing it.....Get on that CNC and make some magic.....lol
Edited by JD74
[email protected]
Thanks.
JPC in Melbourne already produce N1 style replacement OEM pump gears if that is what interests you. http://www.jpc.com.au/ The Nitto pump gears are made from superior material from those though...i would rather not risk it with any material other than Nitto or an external pump.
Edited by DiRTgarage
I was on Nissansilvia forums earlier and came across the powertune gears (again)
http://hardtuned.net/forums/index.php?app=...ttach_id=177301
made out of P20
hows it compare to JPCs 4340 gears? pretty cheap at $350
I am still at a bit of a loss when it comes to these 'Nitto' pumps.....
Where are they made ?
Who makes them ?
Who is Nitto ?
Info is in short supply. Website ? Manufacturer Info ?
Unfortunately these are not a great deal compared to Tomei anywhere else other than Aus/NZ......
Edited by JD74
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
