Just read you are leaving for sunny Queensland next Wednesday. So i thought i would start a thread to say bye buddy! You might still post on SAU but you will be missed in Victorian events.
Take care and all the best, it's been great knowing ya.
Alan
https://www.sau.com.au/forums/topic/28388-bye-predator-gordo/
Things won't be the same without you dude.
I won't be the same. Sure you'll still post each day and we'll have a laugh but it won't be like it is now. Your posts just won't carry the same "ooomph" as they do coming from Vic.
Just like Denham ( sp ). His witty brand of humour isn't the same now he's in QLD a lot.
Whatever you do man, don't let the sun, surf, warmth, tan lines on girl's nubile young bodies, reef tan oil glistening on the bare breasts of their sun kissed goddess forms as they shine temptingly on some heavenly beach. The warm breeze making her their billow around tanned shoulders with a trickle of sweat running between her breasts and pooling in her belly button before easing down to the waistband of her bikini which is all that separates you from..............
"ahem", yeah man, take care and have a great one.
-Ed:burnout:
awwww...Thanks everybody!!
I'll just answer this all in one place :( Anyhow, a cruise is being organised for hopefully this Friday night so hopefully a few of you guys can come along.
Wardest: and whatever that all says..well I like the sound of it! And hopefully I get to do plenty of it up there.
James: See Friday cruise. Having a big party Saturday night. PM for the details, or anybody else who is interested in coming for that matter :) Otherwise maybe Sunday or Monday night or something? not sure.
Nark: /slap.. you know the 33's are better anyhow, why don't you just admit it? :D
Inasnt: Gold Coast to stay with a friend for 2 weeks or so, then mostly like Brisbane unless I decide to stay on GC and commute up the highway each day. Cairns is a bloody long drive though! I may as well drive back to melbourne :)
Evil: Yeah, probably... its just that its been delayed for another 6-8 months or so. Decided to keep the skyline for a bit up in QLD, and do a few extras to it. As long as the QLD job Fairy strikes early, time to do some "stuff" to it and have some fun.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
