  • Replies 716
Posted Images
come and get your front diff out of my kitchen. also have that fancy sump adapter/billet cradle/brace for your 30/26 build ready for you too.
your front diff box has bits of egg and olive oil all over it from sitting on my kitchen bench. come and sink a can or two with me. i'm moving out of slurry hills soon.
f**kin hell fatz where can i get a girl friend whos willing to swing spanners on my skyline!
You got it all bud!
Im as bad as you mate with the nissans lol
Currently i run a 1980 mod diesil patrol non turbo tray back in complete original condition.
Its awsome when you go down town in the patrol and people look at you like your some kinda hic from the back country but i would not have it any other way!
Uploaded with ImageShack.us
You got it all bud!
I've got one of those girls. It's hit and miss being able to get them!
Bit like getting a clean hooker... LOL
Hay fats
Nice car
The 26/30, Is that for the 31 or 32?
6 hour picks
sticker time
some cool cars
i got in trouble for going to fast
felt like i was at the principles office
work that out?
warming up john's car
have to do timing for people in the team... man its cold
this is how busy it gets allday
gtr 2 phillip island 0
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
