  • Replies 716
Posted Images
  • 4 weeks later...
  • 3 weeks later...
this may be the reason why there has been not much prgress on the race car
yes its movemeber so you should sponsor me!
http://www.everydayhero.com.au/von_trapp_family_shaggers
anyway time to do something
mother of god i did some work on the shita
just jap ic hoses
front dive shafts in and lubed up ( ohhhh yea)
oil cooler mounted with cable ties ( yea baby)
radiator test fitted ( header tank set up
wirig re- connected
probably another few hours to get the front end done then bolt up the exhaust put some oil in and kick it inthe bitts
Hahahaha yep there is progress.
Front suspension is all bolted up and uprights done, got the rails ground back and ready to take the plasma cutter to them for the drive shaft humps.
Awd box is also sitting there and floor is marked to be cut out
sexual chocolate.
best pic is the blue 31 interior. should put that interior into the GTR for some much needed class.
how many cars you trying to build at once you clown? and half your pics don't work for some reason. photobucket sucks the big one.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
