  • Replies 716
Posted Images
due to a bun in the oven
Ha Ha was just talking to Pete,,,seems Congrats are in order,,,Nice work indeed the pair of you.
Racing is expensive,,,I know someone that buys babies for the blackmarket,,, could help with blown turbo's and finishing projects. Let me know.
Cheers
Neil.
