wrecking r32 gts4 turbo manual in melb
not many interior parts avaliable
engine complete minus injectors $900
complete gearbox manual $900
tail shaft $150
rear diff $300
drive shafts $150 pair
complete brake setup inc rotors calipers hubs $400
stock suspension front and rear springs and struts $170
left hand door $100
right hand door $100
rear bar $80
rear tail lights $150 pair
boot lid $70
rear cut $200
fuel tank $50
front cross member $50
dashboard x2 $40 each
left hand electric mirror $40
IF YOU ARE NOT HAPPY WITH THE PRICES JUST PM ME AN OFFER AND WE CAN SORT OUT A DEAL
alot more parts avaliable just ask or call 0402090079 parts are located in laverton north in melbournes western suburbs
Edited by SXC_R33
Space saver spare tire and oil pressure sender from the engine please, can pickup on weekend.
Tried calling, no ans. your message bank is full too. :rolleyes:
Edited by GTRPSI
have you got front front upper control arms, third links, lower control arms and castor rods for both left and right?
if he doesnt have castor rods then i do if gtst is the same
but see if he has it first coz its his thread and its only fair
Edited by Sami
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
