Today I planed to cut wire 53 to my ECU to get rid of that pesky 180km/h speed limiter (how often do I get up to those kind of speeds? Once a lap at Eastern Creek :P). When I discovered I had left my electrical tape at work I decided to leave my wires alone and just have a little look around to see where the wires go. I remove some plastic wrapping and I discover... this!
Correct me if I'm wrong but this does not look like work Nissan has done... so I'm trying to figure out what it's for...
Car is 1996 R33 GTS-t
Dyno results are to be expected of the car (145-157rwkW with standard everything)
Only mod it had when I bought it was a Blitz Full Auto Turbo Timer (later scraped for a timer built into immobiliser)
Car still has HICAS
Speed limiter definitely works
If anyone has any remote idea what it could be please let me know as I am at a complete loss lol
https://www.sau.com.au/forums/topic/284542-what-is-this-thing-near-my-ecu/
had to beleive, but nissan put that monstrosity there....they are the same in the 32 gtr loom too.
apparently it's a common earth point for all those wires.
Well... I guess I can take some comfort in knowing that my standards in wiring are exactly the same as Nissan's ie, looks dodgy but is electrically (somewhat) safe :P
Thanks Duncan :)
I have looked at a few wiring diagrams and wire 53 does say HICAS Diagnostic/Speed Limiter on most of them, as well as a couple of guides saying that you can get "hesitation" at around 140km/h. I figure if I cut it and I don't like what it has done I can always wire it back up :P
I've pulled out many RB20 and RRB25 ECU's and that does not look standard. And nissan certainly does not wrap wires with "blue electrical tape"
Are you talking about the brown electrical plug?
Looks like its had some sort of interceptor ECU on there before. Maybe a harness for a SAFC of EManage, unichip, etc?
I was actually thinking of putting a normally closed relay in so when the car reaches around 160km/h it would open circuit wire 53, bypassing the hesitation point automatically. I just can't figure out how I'm going to energise the coil at that point lol
And while you are at it, put a switch on the fuel pump relay too.
Then hide it somewhere :devil:
I already have, though one would call it an immobiliser :(
x2 on the switch on #53.
And a turbo timer is not a "mod"
I will agree, a turbo timer has no performance enhancing ability, it is a electronic relay which bypasses the ignition on a timer. Seeing as most vehicles do not have such facilities as standard, the wiring of the car has needed to be modified for this device to be installed.
Therefore, I say it is a mod. My insurance company also agrees with me on this :)
I'm talking about both the blue tape and the brown... thing...
Weird thing is, the brown thing isn't a plug, it hasn't got any capacity for any more conductors except for where the cables go in. Without pulling it apart it looks like what Duncan described it as, a common point for all those cables.
like I said they are not a plug, and they are common in nissan looms.
here is one in an r32 gtr loom
here are 2 more from a gtr, these ones are under the dash.
all are common earths - if you have a multimeter check with continuity mode - all the wires are joined to each other.
if you reckon these look dodgy...trace through a factory loom and look for their joined wires. simple brass crimps with a bit of tape around them. looks terrible but works ok for 20+ years apparently
Probably not a good idea to have speed signal wires being connected and disconected whilst the engine is on otherwise you will throw up errors, will probably throw your speed sensitive steering out. I'd just put it on a toggle switch or just cut and put some spade terminals on it so you can easily plug them back together.
100% the blue tape is factory, and like others said the brown plug is a common bus for earths.
All in all it looks factory to me.
  • 10 years later...
Car still has HICAS
Hi man,
Sorry to open up an old thread but I cant open the photo of that thing and Im wondering if I have the same thing on my r34. There is a few ECU wires that go to a brown block thing and its giving me all sorts of headaces. Could you post another photo of it
44 minutes ago, joshbarnes said:
Hi man,
Yes, you have the same thing.
It is a buss connector for all your shield grounds. Basically any of the shielded signal wires that go to the ECU, so CAS, MAF, knock, etc, all have their shield earthed through that connector. If you look at the OEM circuit diagram, you will see a dotted line around some of the lines (pin 55, 54, 44, 45, 46, etc) - this dotted line indicates that shield ground.
  • Like 1
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
