Hi guys
Ive been contemplating using Schaeffer oil in my car for a while now but haven't seen anyone here that uses it, i am sure many haven't even heard of it.
I've seen the "bearing test" performed with it and was quite impressed where it out performed many top brands.
I know by no means i should base my decision entirely on this as this bearing test probably just covers one property of the oil, so can u oil gurus check it out and tell me what u think.
I have been using Redline in my cars and i notice after a while a little disappears ie. in the Rb26 and also the Qg15.... and mind u, the Schaeffer is more expensive than the Redline!
https://www.sau.com.au/forums/topic/284603-schaeffer-oil/
its fine and well to be buying the best quality oil and the most expensive oil but you should be asking, what is the correct grade of oil, how often do i change it, how i drive track/street, do i need to overfill fill it........(RB cheap fix). the oil debate will go on until we run out. i have a 80pg book about motor oil on my computer. it a well worth read. What car are you putting this oil in to give everyone an idea as to what recommend. As person above ^^^
Edited by Greekos
https://www.sau.com.au/forums/topic/284603-schaeffer-oil/#findComment-4783241
If its the bearing test i'm thinking of, it has been largely discredited and shouldnt be used as a basis for making an oil choice. From the data i've seen the Redline is damn good, so unless you have a credible source showing its better than the Redline, i'd say stay with what you have. Especially seeing as how the Redline is already super expensive. How much does a fill cost you?
https://www.sau.com.au/forums/topic/284603-schaeffer-oil/#findComment-4783968
Like i said, i do not want to base my decision to use Schaeffer solely on the results of the "bearing test" because i know that will be totally inaccurate.....
Thats why i need u guys to check it out as i don't know shit when it comes to the specs when dealing with oil!!! I use Redline because it is highly recommended here, the only problem is that a little disappears after a while and this is with absolutely no blowby on a healthy engine.
Redline cost me about $66 (5qts)
Schaffer cost me about $82 (5qts)
I've converted it to $AUD for your benefit.
I believe Schaeffer is American based http://www.schaefferoil.com/
https://www.sau.com.au/forums/topic/284603-schaeffer-oil/#findComment-4784564
Nice bump there...
I think in the oils sticky, someone mentioned a Used Oil Analysis (UOA) kit that you can buy.
Personally I use German Castrol (GC) and switched to Amsoil recently, might switch back to GC again, its only 0w30 but its a thick 0w30 so closer to Mobil 1's 0w40.
If you really need to do oil research Bob is the oil guy (the forum) is very useful.
https://www.sau.com.au/forums/topic/284603-schaeffer-oil/#findComment-4803939
No such animal. It's either a 0w30, or it's something else.
Sorry I should not have used the word "thick", it breaks down less easily than most 0w30's :)
Its well known on bob is the oil guy, you'll find the FAQ for german castrol here
https://www.sau.com.au/forums/topic/284603-schaeffer-oil/#findComment-4806363
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
