The stock SMIC is a fairly efficient piece of equipment.
Unless you plan to up your boost in the near future, spend your money elsewhere.
Other than that, you can install one for cosmetic effect and if you end up increasing your boost later on, it's there.
but if i install one and keep it stock boost will the car run abit better then having a smic
perfomance-wise told me it would run abit better and that the more air flow the safer ?
I would stick with the stock one mate.
Installing an aftermarket cooler will actually make the engine a little less responsive due to the longer pipework.
thanks its all interesting to hear, because other guys as i said in a previouse post, well they said my car might even gain 1 pound boost and it would run alittle bit better, they said it might lag a tiny but but you wont notice ?
I wouldn't do it. Adds a lot of extra piping on RB25's because their turbo outlet and throttle body are both on the same side so lots of piping wen u add a front mount unless U get a forward facing plenum.
i just like the look of them thats all, so it will not give me any gain wat so ever if im running stock boost ?
No gain what so ever, been stated a few times now.
Just longer piping, potentially less responsive.
ok then so that has cancelled out my plans 99.5 % lol
its just sometimes when my car is boosting on the freeway i dont get much pull and a mechanic said its prob coz your smic is heatsoked ?
You're running a stock car... Of course its not going to have serious pull.
ohh so nothing is wrong ok kool
thanks for that im new to the scene sorry about the ameture questions
when im at a set of lights there is pullback but when on a freeway just a tiny bit and just picks up speed fast, a mechanic told me it wasnt pulling hard because smic was heat soked
but thanks for clearing that up i didnt know !
drop it down to 3rd on the freeway and see if it pulls better. :down:
"IF" it is getting heat soaked you would probably be better off putting some better ducting and a little water mist sprayer in front of the SMIC then going a big front mount on a completely stock car.
yer i dunno coz i was planning on nistuning the car later on so i guess i could get fmic now and worry bout rest later?
Just a thought, but assuming you already have exhaust and air filter upgrades, You would be better off buying an boost controller next, install & up the boost a little bit when you get it tuned. Then when your used to that and you want even more boost, upgrade to a FMIC then retune.
Theres plenty more mods you can do before the SMIC will need upgrading.
i mainly want one coz it makes the car look better looks really good with one on lol
Im glad you said "potentially" ;)
I put a Blitz LM on my R33, running R32 actuator and as far as i can feel it didnt make any difference at all. Marginally shorter piping than your average hybrid piping though. But still longer than SMIC clearly.
My R34 SMIC on my R33 got heatsoaked to the point it would burn my hand if i touched the hot side, and only marginally cooler after a short spirited drive. And it just felt shithouse. So i opted for the front mount. Never looked back.
Yeah no way your SMIC would be getting 'heatsoaked' if you are driving at 100km/h or so already.
Just put're in 3rd gear, RB25DET GB+Diff goes up to 160km/h or so in third and you should feel a bit of pull but I think stock you'll only really feel pushed in the seat in 2nd?
Personally though, as long as at some point you may be putting the boost up or maybe you just want the looks or the fun of modifying the car, I would just do it. Any cons produced by longer piping would probably be neglible and at least it's done which may motivate you to do more to the car.
yer just anotherthing if i dont have any cold air intakes or pod is having a fmic still considered unroadworthy in victoria ?
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
