Hi Prank
Know you are really busy with all this stuff at the the mo but HELP--
My usual login is blackdoggette - I can login ok and forum recognises I am online but as soon as I try to post, look at my profile or PM someone I can an error back (largish) that looks like I am not activated or something???
I joined about a month ago so am assuming with the recent forum death and re-birth that something is very amiss...
I sent you an email (of course I tried to PM and post but couldn't) very early today and hadn't heard anything so I joined forum again tonight using this username - Nissy
Help
---many many thanks
when it gets all sorted I will let you know and you can delete this account
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-595091
  • Replies 64
Hey just a fiew things, you probably know them all already.
1. in the change avatar option there is only the option to delete.
2. Webmail isn't working? Outlook works fine tho :rofl:
3. FTP to upload to webspace doesn't work? (ERROR: Windows can not access the folder, make sure you typed the file name correctly and have permission to access the folder.) in the pm you sent me you said
*Server; ftp.skylinesaustralia.com
*Location; http://www.skylinesaustralia.com/members/endorean/
thats not my username perhaps its pointing to someone elses webspace?
That is All :D
Thankyou Very Very much :)
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-598140
PranK,
It appears that you can edit other people's gallery images, manipulate them and add text. Obviously there is a very bored/sad soul out there which finds it funny. Don't know what the login area for it is for? Username and P/W don't work there??
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600010
You would have to be pretty bored. Would be good if the only people who could edit your photos, are you and the moderators. Still wouldn't stop bored souls posting rubbish though and as the gallery grows, it may become a problem keeping track of it all. It will be a damn shame if stronger restrictions then that have to be put in place.
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-600414
FTP should now be working.
Sing out if theres problems.
C:>ftp skylinesaustralia.com
Connected to skylinesaustralia.com.
220 SAU FTP
User (skylinesaustralia.com:(none)): [email protected]
331 Password required for [email protected].
Password:
230 User [email protected] logged in.
ftp> put boot.ini
200 PORT command successful
150 Opening ASCII mode data connection for boot.ini
226 Transfer complete.
ftp: 192 bytes sent in 0.00Seconds 192000.00Kbytes/sec.
ftp> ls
150 Opening ASCII mode data connection for file list
boot.ini
ftp: 10 bytes received in 0.00Seconds 10000.00Kbytes/sec.
ftp>
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-602587
dude all links that don't point to forums.skylinesaustralia.com/forums don't work. I think it used to be either forums.skylinesaustralia.com OR www.skylinesaustralia.com/forums.
Even the notification emails are wrong :D
https://www.sau.com.au/forums/topic/28493-bug-report/page/2/#findComment-606797
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
