  • Replies 198
Posted Images
Is that the fisheye lens?
I did the stupidest thing on the weekend.
Was going to learn how to use my camera and my bf had been going through the documents and put the 'manual' on my desk, so i was reading this trying to learn how i change the FOV and shutterspeed or whatever and it was REALLY unhelpful, so an hour later i gave up, and it turns out it was the camera tips booklet and the manual was elsewhere :(
so i STILL dont know how to use my camera.
I heard those different lenses arent that expensive though? like colour filters etc.
Was going to learn how to use my camera and my bf had been going through the documents and put the 'manual' on my desk, so i was reading this trying to learn how i change the FOV and shutterspeed or whatever and it was REALLY unhelpful, so an hour later i gave up, and it turns out it was the camera tips booklet and the manual was elsewhere :rofl:
Lol, what camera is it? Most tips booklets are pretty useful still... Most lenses are expensive.. :(
ahaha u said most lenses arent expensive then went on to say like colour filters?... filters are different to lenses. a filter is what you put on top of a lens to get a certain effect... use photoshop though its more adjustable
There are some things photoshop can't do as well as certain filters. :D
Yeah i realise i was talking about lenses then talked about filters. I know theres a difference, it was just a tired moment.
and i cant remember what camera i have, its a canon, but i work on a mine, live at the mine and the cameras at home.
Do ya know how it compares to the canon 15mm 2.8 Fisheye? Maybe we should do some comparisons on full frame bodies. :)
Yeah, Tripod bench testing sounds like a good idea. :)
Pics from today...
Moar to come. :)
IM jealous ian!! I want that camera and lens..
Sometimes i find i need two nd8 filters on a bright day...
Plenty of 2nd hand 5D's floating around Sidd! Get off your arse and start trawling FleaBay! :)
On a full day of sun i'd use 3 ND8's to be sure. :)
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
