  • Replies 328
I live in singleton and get to cruise the putty a fair bit but the last couple of times i have been along there i have noticed the halfway house is burnt down and i doubt it will be up and going by the time the cruise rolls by. Just thought i would let yas know.
ah ok! thanks for the info.. if it's burntdown we will just continue on then.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
