Hi, recently bought a N/A r33. Didn't come with an owners manual.
Just wondering if its ok to run the car with standard unleaded (91 Octane) or will this damage the car?
Filled it with premium (98 Octane) the first few fills and it drank a tank in less than 3 days, and i don't drive like a maniac at high revs either.
Its drinking the standard unleaded much more slowly which is good for the everyday driving i do and cheaper, but i just wanna know if this is ok for the car?
Thanks Justin
https://www.sau.com.au/forums/topic/286403-the-correct-fuel/
Your car is built for a higher octane (100?). I would use at least 95
E10 is good, its cheap and should hold off those nasty noises - until you start winding up the timing that is. Even better, E85
Do a search for fuel consumption, plenty on here about possible causes i.e. sensors, filters etc.
one of my mates used 91 octane fuel on his skyline and the engine went bang later. higher octane fuel reduces the chances of detonation which is why i only use BP Ultimate 98RON( WA doesnt have Shell optimax grrr :P ) more expensive fuel but better than expensive repairs.
Edited by R33_NICK
I read somewhere that NA skylines were able to run on regular japanese fuel while the turbocharged versions ran on premium. Im pretty sure regular japanese fuel is 89 AKI which equates to around 94 octane so maybe try 95 octane? Keep in mind I know next to nothing about skylines so this may not be true
technically you shouldn't get any real difference in economy from regular to premium. the ecu reads how much air is going into the engine and puts in the set amount of fuel for that afm voltage and tps position. other things will affect economy much greater than the type of fuel. you don't just take into account what revs you are doing, but how far you push the accelerator down. someone flooring it but only reving to 3000rpm will use more fuel than someone who revs to 4000rpm but uses half the throttle percentage. also the O2 sensor controls the fuel economy at light throttle loads, so if that dies your economy goes bad. also if the thermostat is shot and your car takes for ever to come up to operating temp then you will get poor economy as well. or you could simply have a slightly dicky fuel gauge. then there is your driving environment. if you have to stop at traffic lights often then you will get poor economy compared to someone who drove the same trip but got a green light every time.
finally, you said that a tank was lasting you 3 days, but the more important information is: how many kms were you doing in those 3 days, and how many litres are you calling "a tank"? i have used a full tank of fuel in a day, but i also drove 600km on that tank.
agreed, you could say you used 2 tanks in one day - but if u were driving from brisbane to sydney that would be understandable..
so more info pls?
i would however stick to bp ultimate or mobile 8000 buddy
98ftw :woot:
Edited by astrotristan2
to me if you can afford to own an import / modified car, you can afford to put 98 octane fuel in it at least! It just never ceases to piss me off that though the price for unleaded can vary up to 20cpl, ultimate etc hovers around the 1.38-1.45 mark constantly!
When I had my NA 33, I always put V-Power in it for about 1.5years and I went to sell it, after the buyer has put a deposit down, I just put in cheap normal unleaded.
And straight away, I could notice the difference, the car's responce is so much more laggy.
As for mileage, I find putting 98 in, can get me more k's than normal unleaded.
  • 3 months later...
Like he said, if you can afford modified car u can afford 98 octane fuel
Shell V-Power ftw
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
