My 1st Time @ Winton Drift Experience
Hey guys, So it was my first time at winton drifting! It was so good! I also entered the track and it was unbelivable! it was the bestest experience ever. My car was running at 233kws and thrashing it the temp was at 81c with a alloy radiator! . For drifting i had a 2way diff , coilovers and a rear adjustable sway bar! but the bad thing was HICAS was activated... i hope it didnt make a diffrence.. I also spun out a couple of times onto the grass! . I went through 1 pair of tyres and also used not much petrol? . The morning was also cold but then in the afternoon it got pretty hot. I also saw 2 SAU members RED r33 drifting he was going off tap going nuts.. and i saw a White R33 with a Camera on top.(had a SAU sticker) . Anyways who else went?
w2048.png[/img]
Edited by geraus
https://www.sau.com.au/forums/topic/286737-my-1st-time-winton-drift-experience/
Yeah mate, white R33 was me. I had a great day. Looking forward to the next oppertunity I can get out there. Only way to get better is just keep on getting as much track time as you can.
Hey guys thanks heaps for the comments!, Yeh i have experience lol, street experience, i can connect the far far away big S-bends......... but the thing is HICAS is stufffing me up! WARLORD you should come down its really good! guys should come down!
car looks nice mate, how was it first time drifting? you had any previous experiance? im really keen on going onto the track for drifting but i have NO experiance drifting.
You need to man up Bas and give it a go! I'll drive your car up there for ya!
Good stuff geraus. Looks like a good turn out up there.
Did you improve Brendan? How did ya go?
We're hoping to make the november or december one in the new car.
im gonna hold you to that russ, you can just swing past mine, and then we will cruise it there (with you driving mine obviously)
when is the next meet?
if its november/december, then my high mount setup and 2 way diff will be in 100%, if not then just the 2 way will be in lol.
thanks russ :banana::D:D:D:D
hey geraus
tets' lover hahaha
good to see you learnt from my teaching of drifting.... if it wasnt for me you wouldnt have known how to link the S bend with a slight tap of the brakes for transition lol
good to hear u had fun man
p.s. u know me from west meet (tets' mate)
thanks russ :P:D:D:D:D
The december one is probably more realistic with the sil so that would be a good time I reckon.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
