Nice brake kit!... drooooool
those 2500's will be fine, better pad for the street IMO... the 3000's just chew up your rotors when cold... you won't run out of braking with that setup:)
you don't need to learn to drive, you have a GTR, just point it where you want to go and step on the loud pedal! ;) ... best place to start would be on the Deca skid pan and I'm sure there are a bunch of people there who would love a close look at the car... it would be a weapon around the cones with its quick response
Pictorial of more HKS goodness...Hmmm.... 2.8L Step 2 capacity upgrade kit rated 588kw:
Forged Piston kit (nickel plated & piston surface has a final molybdenum coating):
Note the valve relief pre-machined on the piston top
H cross section connecting rods:
Fully forged & balanced counter crankshaft:
Sorry, I did not unwrap the crankshaft for some reason.
The fully balanced crankshaft makes the engine feel much smoother at high rpms, even at idle the engine noise and vibration is minimal.
Nice rod design. I like the extra material where the mating surfaces are between the rod and bearing cap. Makes for less material distortion to push the bearings out of round when the bolts are torqued to spec.
Are you aiming for over 500kw? Just wondering why you went for the step 2 pistons with the nickel coating. Having a ceramic coating instead would have been fine for less power and have been more streetable due to less heat transfer to the oil.
I'd like to see some before and after proof of the V-Cam system working (i.e. actually tuned correctly)... I'm in very close contact with the HKS tuner from Sydney and it's not just as simple as what you've put down.
Nice build.
If you are scared of nailing the loud pedal then you really need to take it to a place like Sandown and open the taps in the thing....just remember the middle pedal and get the thing slowed down as i am guessin the thing will be a bullet.
LOL, makes me laugh that Adam has a similar engine in a rwd GTSt....MADNESS!!!!!
GTRNUR Posted Yesterday, 11:22 PM
Hi GTRNUR,
I am aiming for good low end response rather than peak power, that's why a pair of Garrett's 2860-5s have been chosen rather than a big single banger. I am aiming for over 400rwKw.
I went for Step 2 because that's what Beno recommended. I know its a lame explanation. But every time I deviated from his recommendation I end up getting compromised result.
Roy Posted Today, 02:08 PM
Nice build.
Thank Roy.
Sandown is definitely on agenda, maybe after a run or two at the drag strip first. I am still learning to launch the car properly. The problem is its not the thing to practice on public roads!
Cheers
Matt
Not at all. The smartest thing you can do is put your trust in a builder with the skills of Ben at Racepace. Im sure he has his reasons for suggesting the step 2 kit. Perhaps for a simple a reason as planning for the future, or maybe the valve pockets accomodate more valve lift with the v-cam setup.
How long till the block machining and assembly starts? Are you intending to use your factory engine block or are you building up the RB28 in another N1 block?
Thanks for sharing,
Ian
Hey Ian,
Actually the build is all complete! :D This is more like a retrospective build thread. I guess I am keeping everyone in suspense.
The original NUR engine was kept as a long block and a brand new N1 block was purchased and machined.
Cheers
Matt
Ah... i suspected as much. That explains your comment about how scary fast it is a lot better. If it were that way before you undertook these changes you'd probably never drive the car after the build was finished.
Glad you kept the original engine intact as well.
Thanks for comments guys.
Let's showcase more parts:
Garretts GT 2860R - 707160-5 goodness:
Let's see how much boost these puppies can generate!
Nismo Twin plate super coppermix clutch, rated at 640ps:
I don't know why I did not take it out of the plastic bag for a decent photo :P
Nismo AFM:
Tomei Oil Pump:
Sard 700cc injectors:
So, that's pretty much a wrap up of all the parts for engine rebuild. Note absence of upgraded fuel pump, regulators, boost controller, fuel rail etc., as the stock items are considered to be good enough. Oh, actually I forgot the new N1 block, which I don't have any photos as the engine block was sent straight to machine shop.
wow this is an impressive car! Congratulations on an exceptional build so far.
Think you need the nismo's on there though, but after seeing the nismo's next to the 19" te37's they look small so time for some 19x10.5 lmgt4's...
Do you mind if i ask what you do? Feel free to tell me to bugger off though!
cheers, Tim
Found a photo of the new N1 block mounted on an engine stand:
And out with the 'old' NUR engine:
If there is anyone interested in a genuine NUR long block with low mileage, then please pm me.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
