Hi Matt a great job a Nur spec built to full spec lol.
Im from africa interested in your old motor do you still have it tried to pm you ?
Let me know
Cheers
Adam
Hi shiro ryo
I don't quite understand what you may be referring to? Please elaborate.
Thanks
Matt
I don't think he understands what he is referring to either.
All RB26 R32-R34 head castings are all the same. There is certainly nothing you can identify from looking at the outside of the head.
Looking forward to seeing what you'll do to an R35 if thats what's next Matt.
Hi Shiro Ryo
I switched the NUR engine out because I wanted increased capacity RB. Its amazing what just an extra 0.1771 L of capacity can do to transform the way the engine performs.
I sold the NUR engine as a whole with the Gold cam covers because that usually is worth more money.
I went for black cam covers to match the theme of the car - black and white.
Matt
  • 4 weeks later...
I absolutely LOVE this car.
The black and white, CF bits, Z-tune bits, V-cam, steering wheel, TE37's... EVERYTHING is perfect.
I've always wanted a Nur/Z-Tune R34, and this is probably the best example I have ever seen. I've always loved Bayside Blue, Midnight Purple and Millennium Jade, but the Black on White has changed me, or at the very least added to the list.
Thank-you. Your car is Incredible.
Chris
Hi Matt
The car that will be on the front cover of performance imports 134 is my R33 GTR time attack car you saw it at RacePace last year jack was dropping it off. This will be a great issue tuff track and street GTR's.
Matt - Jason...
Will send some photos just before the magazine issue is out so that you can post some pics on here.... i hope the features look good otherwise the skyline australia peeps will hunt me down :P
Yes, my car spends more time at Racepace than my garage! I am always picking Chris's brains on how to tweak the car more for better performance.
I just got transfer case modified to allow more power to be diverted to the front wheels when power on. This supposedly gives better traction when launching and on corner exit.
I had Hicas removed as well to allow a more stable rear end when cornering at moderate to high speeds. The factory setting of Hicas gives the car a rather unstable feel to the rear end. Besides, all of Racepace circuit and targa cars have Hicas deleted.
Therefore, two more boxes ticked!
I also underwent another re-tune on the dyno and Chris discovered a minor lean spot just as the boost comes on that needed some adjustment. Just a word of advice, dyno-tuning needs to be carried out periodically as the GTR tends to get out of tune with mileage. Power at the Rear wheels was slightly down from 413 rwkw to 407 rwkw (humid day!). Boost levels slightly down, probably due to high barometric pressure.
All other systems were checked to ensure optimal operation and the car is thankfully A1.
Hmmm... just a few more thing on my list to be done.
Finally, thank you all for the continued interest and support. This thread has over 100,000 HITS!!! :thanks:
Guys, I almost forgot. I would like to buy these wheels....
Specs:
Second hand Work Meister S1 20"X10.5" in chrome and get this - Fr offset 0; Rr offset -6.
Cost: NOT cheap
Discontinued specs, rare
I did a bit of calculation and the front is going to stick out 21mm more than my TE37s and Rear by 27mm.
Couple of questions:
Would the wheels clear my AP brake calipers?
Would the inner rim clear my Tein RS?
Would the outer guard rub on the rear guard?
what are the specs of your current wheels?
how much room do you have between rim and shock at the moment?
whether the tyre rubs on the guards will depend on things like tyre width and sidewall height (how much stretch you have)... and camber
those rims come in different 'disks'... it simply means how far out the spokes are pushed towards the outside of the rims... you can have 2 wheels with the exact same width and offset but one will have the spokes pushed out further to accommodate big front brakes
brake fitting is a trial and error thing mainly... TE37's are really well designed for clearing large calipers... Work Meisters, not so much
if you can get them to fit they will look fantastic... but will be some dicking around... most importantly fitting over the brakes and not fouling on the shocks are most important... the other stuff can be worked around
EDIT: worst case scenario you maybe able to run spacers... but on a car like your I dunno about spacers... ask Chris about that
if you did buy them and then find they dont clear your brakes you certainly wouldnt have any problems selling them again
i wouldnt think clearing your struts would be an issue with that low an offset either
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
