Hi all,
I have a strange problem... my R33 GTST (stock as a rock) wont start, it wont even engage the starter motor. one day it was cranking to start, then the next time i tried... NOTHING, further to this my reds on my dash come up as usual if you are turing your car on but I can pull the key back out and they all stay on.
the only way to get the reds OFF is to pull the battery out.
I do NOT have an immobiliser on the car yet so it's not that besides which they stay on permenantly anyway...
I just got the car, it had the engine replaced but wasn't finished being put together yet so I finished it up, all that needed to happen was to have the possitives connected to the front relay box. Anyway as stated above, it was cranking it just didn't have enough power left in the battery to kick it over properly... I replaced teh battery and now I have this problem.
My Auto elec friend checked it out and thought it might have been the ECU, so I have replaced that and the ploblem still exists.
Has anyone seen this before or does anyone have any ideas? I'm completely lost on this one :P
Any help would be greatly appreciated.
Thanks,
H
https://www.sau.com.au/forums/topic/287878-car-wont-start-reds-stay-on-help/
yes there is one there, but I have pulled it out,.. just unplugged it from the loom.
But how would that explain the fact that it was working before? have tried plugging it in and taking it out a few times, but no joy...
any other thoughts anyone at all?
An air gap?
How on earth? are you suggesting there is an air line that is supposed to be plugged in? I ask this feeling a little sheepish because that seems a little strange... I have installed a few of these (pure electrical)... eitherway, I will have a look at the relay it's plugged into to see if there is a problem there.
Although I have unplugged these before aswell for rego purposes... never had the problem.
Still not sure what else to try.
Airgap = two electrical contacts that don't touch
You have a live ignition wire going into the turbo timer and then it comes back out again and carries on to the loom. If you unplug the timer you should have open circuit.
A turbo timer is just a fancy on/off switch, if you take the switch out then you have no current flow. So unless you bridge the two appropriate wires ie join them up using a link wire then you have an airgap.
Ahh, understood, I thought for a moment you were talking about an air line...
all the same, i will go remove the timer from the system altogether and see if that helps (connecting all wires to factory state).
Would that explain why the reds are staying on?
we also have the problem of the starter not engaging... with previous turbo timers I have been able to engage the starter even when the timer was on and doing it's thing regardlss of whether the car is running at the time.
Anyone got any thoughts on this ?
Thanks for your help so far Trident, really appreciate the input.
It sounds like it'd be the timer, or at very least be something to do with the wires going to the timer/ignition etc. Make sure you haven't pulled something out/loose with all the fiddling, if you get me.
It's manual.
Also I had my auto electritian coem round last night...
he removed the turbo timer wiring completely, problem still existed. He then pulled all the blugs out of the ignition and probed them, we could get the lights to go off by effetively earthing out a wire... that wire went to the starter motor, so we disconnected the starter... the problem still existed BUT the lights would go out if we earthed a DIFFERENT wire this time...
It's all very strange particularly because the problem didn't exist a week ago and has popped up .
so in summary, the car is now 100% stock, no timer, controller or anything else.
The problem is still there, no starter engage, red's won't go out... there is NO alarm or immobiliser on this car.
Going to have to go to the wiring diagram on this one, but not being as technical as some I have no idea what we will find...
any other ideas would be great in the mean time guys.
cheers.
will try putting into diagnostic mode tonight...
we pulled all the plugs in the bastard out and still the problem exists... anyone think of anything new?
I will update with anything the ecu fesses up tonight.
cheers for the idea. now all I need to do is figure out HOW to put it into dig mode... also whether I will actually be ABLE to if it involves using the ignition... cause it doesn't turn off.
No alarm... no immobilizer, no turbo timer.
She is totally stock now with NOTHING aftermarket, and no original immobilizer or anything like that... I don't think they ever had them factory anyhow ;)
My electrician thinks that perhaps there is a bad earth somewhere in the car, but I just don't know what could cause this, we have looked at all the wiring we can, all the earths, nothing.
Any other ideas? Happy to go over what I have already done.
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
