Was on the dyno today... and was chasing a issue.. no one noticed this...
I was puzzled so got someone else to drive the car on the dyno while i inspect the engine bay and guess what i saw?
man its times like this i love my job... i cannot stop laughing.
that is nasty. just imagine how much a restriction it must be to be able to suck itself shut. even if you put a rigid frame in it the restriction it's causing is huge. would be interesting to measure the vacuum in the intake pipe!
Want to thank you for this thread, I've just read it all and you're doing things lots if us wish we could!
All this talk of big fat 4wd's with monster snails is giving me some evil thoughts though!
Any idea where I can go to read and learn more about the particular requirements for each? Is the Toyota or Nissan a better place to start you reckon?
And your car, it has R34 Gtr diff gear in it. Yyyyyyyyucky! :)
  • 3 weeks later...
here the land cruiser 1fz and the nissan tb48 are just as popular as each other.
people like the nissan better because of the VCT, (they call them VTEK) and people like the land cruiser because when you build them they can take a massive amount of power and they are half the price of the vtek engines.
Just do exactly what you would do with a skyline except go for some big big cams and lower then 8:1 compression and get a gt45 turbo :)
R34 gtr ? damn.. can i just drop a r32 gtr diff into it?
Here is a car i tuned the other day... Starting to like Haltech more and more these days.
nah the manuals are the strongest box's
I picked up a full r32 gtr rear diff today, it cost me $430 us, then a friend offered to help me go pick it up, and offered me a brand new set of tomei pro cams lash type 270s in box, 2 tomei cam gears in box and brand new 1.2 mm tomei head gasket for my old r34 diff, who was i to knock back his offer? and he actually gave me them... they are legit lol. its going on my rb30
Also when i was at the place today picking up the diff, i tripped over a Holden RB30 single cam with auto trans, i swear i had to look twice, i thought i pollymorphed into wrecking yard in sydney for a second and had to get my bearings back... WTF. and they only wanted $400 for it, it definatly came from Aus they knew what it was.
UAE is one big f**king surprise after the other i tell you, might go and pick it up next week, need to try convince the boss to use it for his drag car.
  • 1 month later...
Yes :)
Okay, i pretty much blew the GT35r, i drove it for a while when it was half gone and then it jammed and wouldnt even spin, and started spitting oil :(
This is my second GT35r on this car, they last less then 4 years, both turbos lasted 3 years each! sucks! is this normal for the BB GT series turbo's?
So i got a new list of parts to install the car, what a perfect time! do it all together!
Parts to go in motor!
Nissan Infinity Throttle Body and backing plate
Tomei adjustable cam gears x 2
Tomei 1.2mm head gasket (not needed)
Tomei 270 cams, hydro types (no springs as of yet going to try my luck the lift aint too much on them)
Bullseye 259 turbocharger
Removed plenum, did this job myself.. had no cars to tune that night
Throttle body plate welded to plazmaman plenum and nissan infinity throttle installed. its huge!!
Bye bye stock cams, we have been through alot together! Summernats, power cruise, WSID, 3 different countries, all kinds of street racing and drifting, 10.8 seconds at 135mph - time to move onto some upgrades, emissions tests not needed here!
Cams out!
post-1240-0-83751800-1316211861_thumb.jpg post-1240-0-40284900-1316211874_thumb.jpg
I decided to try my luck and find some parts to freshen up the cam train of the ol RB30DET, so i looked around, to my suprise i found some goodies to make everything back to new again! I could not believe it!!!
1x RB30DET cam belt, old stock Mitsubish diesel item, it had sooo much dust on it. (you wont find a RB25 one here but the 2530DET you can!)
1 x Timing belt tensioner
2 x cam front seals
1 x crank front seal
Total price??? 175 UAE Dirams, converted to english ?? $51.00 AUD. FIFTY 1 DOLLARS. WTF.. Nissan parts are sooo cheap here! You guys are getting ripped back home!
Also i snapped a cam cap bolt taking it out, the indians working in the shop found out, bring the big welder out and i start shitting the gear WTF?? they weld it up and put a bolt on it and remove it no problems, but finding a new bolt? i looked everywhere, called all the nissans and nothing.. then i had a silly idea to check if the nissan TB48DE cam bolts fit, and what do you know? EXACT FIT!!! but they have been changed and look stronger then the RB25 ones! and we have many of those in the spare bolts bin in the engine build room, WINNER!!!
New cams installed, and ready to put back together
Car should be running again, the turbo is a S259 bullseye, borg warner, i am after a good streetable drift setup, i hear from people with experience from this turbo that says on a cammed rb30det it should make full boost before 3000rpm and up to around 500rwhp, if so il be one happy man!
Stay tuned for more updates, might add some water meth injection also.
Anyone have any ideas what i should do with the solinoid of the VCT ? i want to remove the wires and use it for my water meth injection, can i just remove the solinoid and block it? leave it disconnected ? or connect it to ground perm?
if your not running vct just leave the solenoid in there unplugged. or a short bolt if you have one in the right thread, dont block up the oil gallery though as it feeds the front cam journal aswell as the vct
no results yet, still trying to get my hands on 5 litres of 300v competition oil before loading it up, the turbo sounds great! just like a t51r!
I know its not skyline related, but this is a car i tuned yesterday.
its a packed kit. do not have any pulleys for it.
the headers and free flowing exhaust apparently brings the boost down a little also.
we will get heads and get a pulley for it later on. depends on the customer
421rwhp on less then 20psi, car sounds great and it burns the tires pretty good =)
Got boost control issues, its not going up when i tell it to. need to investigate solinoid and hoses and fix a exhaust leak on the manifold.
is that good power for the s259 ? anyone know?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
