Was on the dyno today... and was chasing a issue.. no one noticed this...
I was puzzled so got someone else to drive the car on the dyno while i inspect the engine bay and guess what i saw?
man its times like this i love my job... i cannot stop laughing.
that is nasty. just imagine how much a restriction it must be to be able to suck itself shut. even if you put a rigid frame in it the restriction it's causing is huge. would be interesting to measure the vacuum in the intake pipe!
Want to thank you for this thread, I've just read it all and you're doing things lots if us wish we could!
All this talk of big fat 4wd's with monster snails is giving me some evil thoughts though!
Any idea where I can go to read and learn more about the particular requirements for each? Is the Toyota or Nissan a better place to start you reckon?
And your car, it has R34 Gtr diff gear in it. Yyyyyyyyucky! :)
  • 3 weeks later...
here the land cruiser 1fz and the nissan tb48 are just as popular as each other.
people like the nissan better because of the VCT, (they call them VTEK) and people like the land cruiser because when you build them they can take a massive amount of power and they are half the price of the vtek engines.
Just do exactly what you would do with a skyline except go for some big big cams and lower then 8:1 compression and get a gt45 turbo :)
R34 gtr ? damn.. can i just drop a r32 gtr diff into it?
Here is a car i tuned the other day... Starting to like Haltech more and more these days.
nah the manuals are the strongest box's
I picked up a full r32 gtr rear diff today, it cost me $430 us, then a friend offered to help me go pick it up, and offered me a brand new set of tomei pro cams lash type 270s in box, 2 tomei cam gears in box and brand new 1.2 mm tomei head gasket for my old r34 diff, who was i to knock back his offer? and he actually gave me them... they are legit lol. its going on my rb30
Also when i was at the place today picking up the diff, i tripped over a Holden RB30 single cam with auto trans, i swear i had to look twice, i thought i pollymorphed into wrecking yard in sydney for a second and had to get my bearings back... WTF. and they only wanted $400 for it, it definatly came from Aus they knew what it was.
UAE is one big f**king surprise after the other i tell you, might go and pick it up next week, need to try convince the boss to use it for his drag car.
  • 1 month later...
Yes :)
Okay, i pretty much blew the GT35r, i drove it for a while when it was half gone and then it jammed and wouldnt even spin, and started spitting oil :(
This is my second GT35r on this car, they last less then 4 years, both turbos lasted 3 years each! sucks! is this normal for the BB GT series turbo's?
So i got a new list of parts to install the car, what a perfect time! do it all together!
Parts to go in motor!
Nissan Infinity Throttle Body and backing plate
Tomei adjustable cam gears x 2
Tomei 1.2mm head gasket (not needed)
Tomei 270 cams, hydro types (no springs as of yet going to try my luck the lift aint too much on them)
Bullseye 259 turbocharger
Removed plenum, did this job myself.. had no cars to tune that night
Throttle body plate welded to plazmaman plenum and nissan infinity throttle installed. its huge!!
Bye bye stock cams, we have been through alot together! Summernats, power cruise, WSID, 3 different countries, all kinds of street racing and drifting, 10.8 seconds at 135mph - time to move onto some upgrades, emissions tests not needed here!
Cams out!
post-1240-0-83751800-1316211861_thumb.jpg post-1240-0-40284900-1316211874_thumb.jpg
I decided to try my luck and find some parts to freshen up the cam train of the ol RB30DET, so i looked around, to my suprise i found some goodies to make everything back to new again! I could not believe it!!!
1x RB30DET cam belt, old stock Mitsubish diesel item, it had sooo much dust on it. (you wont find a RB25 one here but the 2530DET you can!)
1 x Timing belt tensioner
2 x cam front seals
1 x crank front seal
Total price??? 175 UAE Dirams, converted to english ?? $51.00 AUD. FIFTY 1 DOLLARS. WTF.. Nissan parts are sooo cheap here! You guys are getting ripped back home!
Also i snapped a cam cap bolt taking it out, the indians working in the shop found out, bring the big welder out and i start shitting the gear WTF?? they weld it up and put a bolt on it and remove it no problems, but finding a new bolt? i looked everywhere, called all the nissans and nothing.. then i had a silly idea to check if the nissan TB48DE cam bolts fit, and what do you know? EXACT FIT!!! but they have been changed and look stronger then the RB25 ones! and we have many of those in the spare bolts bin in the engine build room, WINNER!!!
New cams installed, and ready to put back together
Car should be running again, the turbo is a S259 bullseye, borg warner, i am after a good streetable drift setup, i hear from people with experience from this turbo that says on a cammed rb30det it should make full boost before 3000rpm and up to around 500rwhp, if so il be one happy man!
Stay tuned for more updates, might add some water meth injection also.
Anyone have any ideas what i should do with the solinoid of the VCT ? i want to remove the wires and use it for my water meth injection, can i just remove the solinoid and block it? leave it disconnected ? or connect it to ground perm?
if your not running vct just leave the solenoid in there unplugged. or a short bolt if you have one in the right thread, dont block up the oil gallery though as it feeds the front cam journal aswell as the vct
no results yet, still trying to get my hands on 5 litres of 300v competition oil before loading it up, the turbo sounds great! just like a t51r!
I know its not skyline related, but this is a car i tuned yesterday.
its a packed kit. do not have any pulleys for it.
the headers and free flowing exhaust apparently brings the boost down a little also.
we will get heads and get a pulley for it later on. depends on the customer
421rwhp on less then 20psi, car sounds great and it burns the tires pretty good =)
Got boost control issues, its not going up when i tell it to. need to investigate solinoid and hoses and fix a exhaust leak on the manifold.
is that good power for the s259 ? anyone know?
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
