  • Replies 109
Was that on the warm up Dane? haha.
yeh was a pretty good day.
fighting with high water temps tho...
would have liked a 1.40.x but could only really get 2-3 laps in.
russ killed me in the super sprint....heaheah
coming into v8 turn one, i was like, yeh i know i can break later here and catch up to him....nup!!!
totally psyched me out.
lol
haha. You were on me till I got some temp in the tyres. It was driving like a boat for first half of that lap.
from about 40 second in
Haha I followed the Evo's line as I was fairly close to him, and when I saw him spinning in front of me I tapped the brakes and went too!
Well done again Russ, nice times mate. I was happy with the Rexxy's performance for the day, wouldn't mind taking it out on semi's at some point... and a 42 would have been nice but I'm glad I stopped to preserve the tyres, my wallet is thanking me.
Just looking at results. There were only 4 cars quicker than me (+snowy and Aaron).
And only 1 of them was a WRX. Now that's satisfying! haha
Hey I didn't get a time so you were quicker than me on the day. Take the win while you can! :)
lol i was laughing at the yellow evo. then i saw you arse going around and started to laugh harder!!!
heahea
was a classic.
Tough luck Snowy, hope it goes better next time.
Here's how the spin looked from my perspective:
So come on Russ, the 37.1 was with the 10k:9k springs or have you put softer in ?
Exactly as I recieved them mate. I just threw em in and got an alignment by traction tyres. I've got some cusco caster rods to go in soon with some 33 LCA's. See how that goes.
Russ amazing effort mate.
Thanks bro!
results summary
my compliments to SAU
i was wondering what happened to some of you during the day.
Cars with no results make me nervous ;)
In the end i figured you didnt complete your first lap
XT1337 (royce)
Edited by Subarau
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
