[taken from Rezz's photo thread, because I wouldn't want to detract from the threads purity :D And added here because someone was obviously interested]
Dealership prices (which is what you will find in car classified magazines) -
(obviously could go even cheaper via the owner or via auction)
* the average 95 r33 GTR is somewhere between 1.75-2million yen (you can get them a lot cheaper - but you get what you pay for).
* Decent 96 GTRs seem to be around the 2.3 - 2.5million area
* 97s are around 2.7-2.9ish
* 98s are high 2s - early 3million yen
* Add around 300,000+ for a v-spec
* below average to decent early r33s (turbo) can be had for 400,000 (sometimes less) to 900,000yen. I've seen a few heavily modifed examples (with low kms) go for considerably more than that. SIIs seem to range from around 600,000 to 1.6mill. Bearing in mind that those at the higher end would be showroom condition and modified.
4-doors are a little cheaper.
I've seen r34 GTRs dipping into the mid 3million mark. Nice GTTs are still around 1.8-2million-ish.
Interestingly, a low km late model r32 GTR will still earn a 2million+ price tag - with v-specs worth quite a bit indeed, given their age. Definitely a few 89 models going below the 750,000yen mark - but export demand might affect that.
You can pick up an early r32 turbo for next to nothing - literally.
using today's exchange rate as an example:
500,000yen=$6,312
750,000yen=$9,468
1million yen=$12,624
1.25mill yen=$15,781
1.5mill yen=$18,937
1.75mill yen=$$22,093
2mill yen=$25,249
2.5mill yen=$31,562
3mill yen=$37,874
3.5mill yen=$44,186
cheapest r32 gts-t I've seen for sale at a dealership=$1,136 (but I have also seen several offered for free - as the owners don't want to pay to get them towed away...)
https://www.sau.com.au/forums/topic/28840-current-skyline-prices-in-japan/
I want an r33 gtr in the future, maybe 34 depending on price
estimating you from that data.. you could get a good r33 gtr vspec for about $30,000 AUD + importing shit
so all up your looking at nearly 40K
ive seen a few vspecs for mid 40s
ide have to say for peace of mind.. being able to drive and see your car when you buy it.. i would rather buy it here
well . i will sell you my r33 . 40K . its damn excellent. now its getting the full workout ( similar to the mines response kit ) . :D
Is this the one you let run out of oil?
Or the one your putting a Microtech MTX8 on that you want for $250 cause its all you have?
Or the one that money is no object and you want the best performance possible?
Let us know. Were all interested...
Hey strutto,
I was just gonna say the same thing, first keen on my microtech then i see him posting he only has $250 offering to the other microtech seller!!! :bs!:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
