a guy i know put me onto this earlier today, swears by it and runs them in all his cars, claims he has had it proven with emission tests.
im still heading more in the direction of it being bogus.
a magnet that u 'cable tie' around ur fuel lines which promises too:
reduces up to 25% of fuel;
provides certification to Euro 3 - 4 - 5;
provides quick launch engine on cold;
reduces to 50% emissions of gases: SO, SN, NOx ...;
eliminates cavitation low-quality fuel and coke-deposits;
increases to 15% resource, engine power, retains a catalyst;
raises the temperature of flare heating and air-fuel combustion mixture.
etc
http://www.eng.eastgreencross.ru/egc-produ...-frequency.html
lol is it the magnet that creates the result or that cool cable tie?
the thing is....if they claimed 2.5% decreas in fuel consumption maybe....but 25%? and the manufacturers all haven't noticed?
ahhaha
i looked into this even further there is alot of contradicting information, though i did find out these products and similair products where banned in western australia by The Perth Consumer Affairs department and they advised customers to demand a refund on the product since it does not perform as claimed.
companies continue to make millions of $ from these magnet prodcts over in the U.S
good times
You have to use one in conjunction with the Fuel Catalyst, the fuel treatment pills that you put in your fuel tank, a Hyclone in the intake, coupled to an electric supercharger and have an Energy Polariser fitted in the engine bay for it to have any positive effect :cool:
You have to use one in conjunction with the Fuel Catalyst, the fuel treatment pills that you put in your fuel tank, a Hyclone in the intake, coupled to an electric supercharger and have an Energy Polariser fitted in the engine bay for it to have any positive effect :yes:
:cool: And an earth wire kit.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
