Make sure you get a Genuine Garrett "-IW" internal gate rear housing - Not some cocked up/ported piece of shit.
That is where the boost control problems come from.
If it is not a 100% .63 Garrett -IW housing - do NOT buy it no matter what you are told.
  • Replies 44
^^^ Necessary input. Lol. Nothing wrong with internal gate for those who like consistency.
Another turbo option to go for:
GT2871R. It's a garrett, but more closely related to an HKS. Bit small, but a lot quicker response. most that you'll find is .60 A/R compressor housing, but turbotech over here has one for about 1800 i think it was with a .76 somehow.
I'll keep a close eye on this thread. i'll be doing similar things with my engine.
Can't buy PFCs new anymore can you? Like, from a wholesaler? What'd be the other way to go? I'm sorry to succumb to shameless advertisement, but if haltech can produce enough cash to buy a R35GT-R as a promo car, they're obviously doing something right.
You seem to want a low cost direct bolt on option
What i have learnt there is nothing that is 100% bolt on when it comes to turbo's, will always need some custom work. Had to make custom dump+front pipes along with a bunch of other stuff. Always have an extra 1-2 grand on top of what you expect it to be.
I would go the nismo 740cc injectors as the price different between them and the 555cc is under $100 for the set.
Going for a GT3071 GT3076 etc with the Garrett turbine housing will require all those extra mods from oil & water lines, new dump, intake mods, heat shielding and the costs to get up when you go this way.
GCG hiflow bolts straight back on.
Hypergear has been working hard on making some of their turbos bolt on applications (with minor oil or water line mods?!)
HKS GT-RS bolts back on but with braided lines.
HKS GT2835ProS has a separate dump to the front pipe which may be an issue if you already have a 3" dump/front but otherwise the kit comes with all you need to bolt back on.
Have a look at precision turbo, in the US. They have plain and bb cores, not water cooled, v-band dump, billet comp wheels, 3inch or 4 inch inlet etc good pricing too.
I just bought a PTB5557... I think they're around 875is USD retail.
You'd need a custom oil line ($40), custom dump with a v band flange ( v-band flange and 2 mandrel bends, like $100 tops), 2" 90 degree silicone elbow ($40), 38mm external w/g ($240) and stock manifold mods ($150 odd).
Just another option...
J.
LOL and who told you they don't spike boost? My old supra had a GT3582R Turbo with the twin flappers on the back. spikes boost like f*ken spastic run 22psi with wastegate fully lose and no dump. Had to take it back to MTQs to machine out wastegate port and fit a bigger flappers. They are just piece of casted steel housing machined to shape like any one elses Nothing special at all and certainly do not help on boost control.
Edited by kwickr33
am probably gonna get the hypergear GT3071r, will post result once on and dynotuned
got my Power Fc off ebay for $1060, just jap still advertise them for $2000 brand new as well as Z32's for $299 new
Was the topic at hand - the GT35?
No. It is a 3071 much different.
So keep your rather poor example, and lack of useful input, out of this topic.
No, just saying you are inputting information that you don't even know the nature of. reading some the rubbish you wrote makes me puke, and mislead other members.
I know your are the king of worriers at this keyboard world. This is just my 2cents
Edited by kwickr33
You are talking about a 700hp turbo & flow out the back, vs a 450-500hp turbo and the flow
They are not the same, and very different.
A Garrett IW rear end will easily flow a 450hp turbo's worth of air.
The GT35 IW is a different story, always has been a sticking point.
So - Sorry, but once again i must point out you are factually wrong about the GT3071 having problems with a IW rear.
Just because you had issues with a GT35, has little to no bearing on a much smaller turbo
A "GT2835R" IS a GT3071R , same family of turbine , same family compressor wheels .
The only reason HKS get this cartridge to work better than Garrett does is because they use GT30 based turbine housings in the six cylinder versions . If Garrett profiled their GT30 housings to suit the cropped GT30 turbine they would have a very useful unit .
A .
Edited by discopotato03
Probably worth doing a search and checking out the experiences BHDave had with boost creep on a 3071 with 0.63 IW Garrett housing.
I agree with Wolverine's comments about the product Hypergear are putting out there. There are a few options that seem like they're close to a bolt-up, and at the price point well worth a go. Following the Hypergear thread there seems to be quite a few satisfied owners and reasonably serious efforts to provide after sales support. It'd be interesting to inspect the 0.63 housing they use for the 3071 spec, and to know exactly what cartridge is used ie. if it has the full size 60mm or cropped 56.5mm turbine rotor.
GT-RS would also be a tidy option at the targeted power/performance level if you could source something for a reasonable price.
  • 2 years later...
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
