  • Replies 145
Posted Images
that looks awesome.. is that a 25 or 26 head.. and does that say 3.0L on it?
Yip I have used a R33 RB25 head. And yes I had custom sticker/decal made for the cover to read
NISSAN 3.0
24 VALVE TWIN CAM
I sell the decals on Trademe.co.nz in the parts section for Nissans
(Pic below is earlier than original pic above while the engine was fitted to spare R32 Skyline. It was while I was sorting battery relocation, intake setup and plenum-to-bonnet clearances)
Nigel
Edited by Nigel Nichols
i dunno didnt think there was enough room to go down through the inside of the bay..... Mate has a washer bottle mounted on the front of his car so it sits between the engine bay and front bar kinda deal. Looks nice with just the cooler pipe going through the bay.
Im getting mine put on soonish so just workig out the last couple of things.
Ive often wondered wether you can still use a plazmaman plenum and still keep the washer bottle position??
any one know for sure?? (PM-R33???) Looks like its an easier fit with the Greddy style ones?
i kept it with mine, so yes you can
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
