  • Replies 145
Posted Images
that looks awesome.. is that a 25 or 26 head.. and does that say 3.0L on it?
Yip I have used a R33 RB25 head. And yes I had custom sticker/decal made for the cover to read
NISSAN 3.0
24 VALVE TWIN CAM
I sell the decals on Trademe.co.nz in the parts section for Nissans
(Pic below is earlier than original pic above while the engine was fitted to spare R32 Skyline. It was while I was sorting battery relocation, intake setup and plenum-to-bonnet clearances)
Nigel
Edited by Nigel Nichols
i dunno didnt think there was enough room to go down through the inside of the bay..... Mate has a washer bottle mounted on the front of his car so it sits between the engine bay and front bar kinda deal. Looks nice with just the cooler pipe going through the bay.
Im getting mine put on soonish so just workig out the last couple of things.
Ive often wondered wether you can still use a plazmaman plenum and still keep the washer bottle position??
any one know for sure?? (PM-R33???) Looks like its an easier fit with the Greddy style ones?
i kept it with mine, so yes you can
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
