  • Replies 69
I have a method that I always follow to get back at the fuel companies for crap like this.
1. Check if the person before you has emptied their hose of fuel, if no you gain an extra 20mL or so!
2. Fill up to either $xx.x2 or $xx.x7 so you can get an extra $0.02 of fuel for free!
3. Always when done empty the fuel hose into your tank (another extra 20mL!), careful not to waste any that didn't come out - leave that little amount for the next person.
4. Never use the preset function as it slows down the pump nearing the preset amount of money hindering you from doing (3) and you can't set cents so it hinders you from (2)
5. Always fill up well after sundown as the fuel is slightly more dense so you get more actual fuel per litre.
I feel slightly more content after doing all this at the bowsers. BTW if you use discount coupons it gets more much more complicated with step 2.
EDIT: Has anyone tried Freedom 98 e10?
There was that article in one of the big papers not long ago about how crude oil prices have dropped significantly since the GFC however petrol prices have barely dropped. Just petrol companies trying to squeeze every dollar out of people....
crude dropped, aud dropped - crude rose, aud rose - there's an equilibrium there that keeps prices relatively constant. Not perfect, but relatively constant. Not overly complicated really.
1) wow 20mL!! At $1.50/litre that is 3 cents worth.
2) This is applicable only if you pay in cash and are not buying anything else in the store.
3) again with the 3 cents.
4) have never seen anyone use the preset function?
5) pumps have temperature compensation built in. Even if temp compensation wasn't built in, for a 75litre tank you'd be looking at stuff all difference in volume. If there was a big difference it would end up expanding in your tank and overflow anyway, not to mention all cars would then have to have fuel temperature compensation built into the ECU otherwise your air/fuel ratios would be out depending on time of day.
So, max saving is like 8 cents worth out of a $100 purchase. If you are that concerned about sticking it to the fuel companies I'd suggest riding a bike.
another thing about the getting fuel at night thing, just how much do you think a few thousand litres of liquid in a tank underground is going to be affected by the heat of the day? i'd be guessing that at absolute most it varies by 1%.
secondly, while the fuel is more dense when cold, your fuel tank will have contracted a bit due to the cold (sweet F all, but the difference in the fuel from day to night is sweet F all as well so might as well mention it) so you will fit less fuel into the tank, so it would even out.
and as above, if you pay by card then you are infact paying that extra 2c.
if you really want to stick it to the fuel companies, limit your use. wind the boost down on your car (will save you fuel at high throttle). don't drive around because you are bored. if you drive past a servo everyday but don't fill up then and then make a special trip to go get fuel, change your habbits so you get fuel on a trip when you are going past, or if you drive past a servo all the time yet use a servo that you have to go out of your way to get to because it is the tiniest amount cheaper but takes you 10 or 15 mins to get there, you are probably spending more to drive to the cheaper servo than you are saving.
here's an example of what i'm talking about. for this example i'll use the fuel economy of 10L/100kms as it is the easiest. and lets say that fuel costs $1.45/L, and you fill up with 50L.
ok so at 10L/100kms you are using doing 10km/L. so that means that if you drive 1km out of your way to get fuel you are spending 14.5 cents, so once you take into account that you have to then do the return trip, that's 29c per km out of your way. so you have to be getting fuel at about 0.6 of a cent cheaper per km you drive out of your way, based off those figures. so if you drive 5kms you would have to be saving 3c a litre.
if you get 13L/100kms then it jumps up to about 38 cents per km and you would have to be saving 0.75 centrs per litre, and 5kms out of your way would need to save you nearly 4c a litre.
Back in my country (China) 3 Australian cents is equate to almost 20 Chinese cents, which is enough to buy 2 fried bean curd sticks, I still remember buying them for 10c each back in primary school, taste yummy :P .
BTW we had 1c coins, enough to buy 1 bubble gum.
  • 2 years later...
A year ago, servos were charging about 10c more for 98RON petrol than ULP.
I think if memory serves me that 2 yrs ago, the difference was about 9c
Now that difference has jumped up to 14c and even more.
NRMA has put in a complaint to the ACCC that this must stop.
Any thoughts? Anyone in the know? Y-Y-Y?
NRMA = Toothless tiger
Difference can get to around 16c (between regular ULP and 98) eh?
Or is it worse where you live?
Are "independents" fairer than "shopping centre associated outlets"?
My Chance to rant.
I live in Sydney and work away from home in Orange and i see a massive price difference between fuel types 91/98 etc and between areas.
Most of the time there is over 20 cents per liter difference between Sydney and Orange even on the same day. I understand their are transport costs and lower profits due to smaller volumes but really 20 cents?
So add the 98 octane tax 12-20 cents + "country town" tax 15-20 cents and you feel pretty ripped off.
I worked out the extra fuel bill for 12 months in my stagea @ about 12.5L/100KM paying for 98 and having to fill up in Orange Vs
A second car which was free (parents no longer wanted a claped out old laser) which I just had to maintain and register it.
Lower fuel consumption plus being able to do a round trip from Sydney and back without buying the over priced fuel in orange pretty much covered rego, 3rd party insurance and an oil change.
I grew up in rural NSW 5+ hrs from Sydney/Melbourne and it was only ever 5 cents difference between us and the city back then WTF is going on?
VENT! RANT! RAH!!!!!!!!!!!!!!!!!!!
My Chance to rant.
WTF is going on?
Just cause for lugging a cargo bay full of fuel Tom? Lessens the pain?
Or are you out at Orange to too long a stretch?
I did that a few times but jerry cans + funnel + fuel stench + spilling fuel in my boots one morning.
Bugger that I'll go back to getting ripped off.
I had the Laser as a second car for 18 months I could do the round trip on a $60 tank. Saddly almost 300 000 KMs and two lots of L/P platers have got the best of the old girl.
Ended up waiting for 1/2 hour in line at the cheaper Caltex near work rather than going to the shell near home & ended up saving ~$2.5.
Well worth it.
Were most of the motorists in front of you, MK, women? Or fairly equal gender numbers? Just checking against some theorist on the Today show...
Well it's no fun Tom - stuck on the side of the road on a cold, brisk morning with an empty fuel tank! :P
You gave me 3 minutes credit! - Hey the clock's an hour behind us - so an hour and 3 minutes... hehe...
I use it sometimes when I'm not filling up completely, it's nice to just hold down the trigger and stare off into space until it stops flowing.
Lucky cars aren't powered by coke or pepsi. Then there would be a lot people complaing. Or worse mineral water!!
Yeah but if i don't want to pay for Coke/Pepsi i can buy a bottle of home brand cola for 90 cents and water pretty much for free from a tap.
The cheap alternative to buying over priced fuel.... walking.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
