New hiccup this afternoon whilst tuning. Slipped teeth was the diagnosis. Will hopefully be fixed tomorrow and hopefully finished. Car was making impressive figures before that and sounded great.
1123nm of torque was reached early also struggled for traction at anything over 2000rpm which is a pain.
Here is a pic for the meantime
a194f8aec6b7e7bcbf7c6f90dad3f4c1_zps0288
Posted Image
lookin the goods Scottie.
Can't wait t'il u can post some final dyno results buddy
So far it isyes. Traction really is the biggest killer for me at the moment. Anyone got ideas of how to help with it? Currently running 275 semi slicks on 18's also have BC racing coilovers. Im going to look at softening the rears up. In regards to boost levels Richo was playing around with it at 25-30psi so will see in coming days what it performs best at
1100nm of torques is impressive...good luck hanging onto that :P
GTR rear guards and 315's will help that, but really with the power your looking at, nothing is going to save you :devil:
Im interested to see what he gets out of it once he can finally put his boot through the right pedal!
Most reckon semi's will show a lower power figure aswell. Try and get some cheapy rubber on there so you can compare apples with apples.If it spins, sit in the boot :yes:
Hope it goes well.
Funny you mention sitting in the boot. I said to the tuner to just throw some of the old motors he has lying around in there for some weight haha
You can mess with any dyno, Greg's V6 rodeo gave somewhere around 350kw on the dyno at our most recent dyno day.....lol
accurate would be running it as you will on the street/strip. no point talking numbers if you can't actually show them when it counts.
imo.
  • Like 1
imo.
Agree to some extent.
Most 'talk numbers' using street tyres on the dyno. No doubt the results will be compared with others cars so if he is using a tyre that is claimed to produce a lower reading there will always be that differential, let alone the dyno and a gazillion other things, which will make comparisons more difficult.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
