Its been quite a while since Ive posted anything of actual substance in here.
Over the past few weeks Ive gathered a few parts together.
Standard S2 front bar
R33 sedan indicators/fog lights
Front lip
Stoptech Calipers
Slotted Rotors
Big thanks goes out to Mike for helping me out with these brakes. Great bloke to deal with. Here is a picture of the brakes
Here is the front bar, lip & lights combo. Quick back yard paint job
Size comparison between standard R33 front brakes and the new Stoptech calipers
Fitted.. perfect amount of wheel clearance
Now for the front bar combination. I trialed the full sedan light setup in the bar and I liked the look of it
Due to the FMIC i had to cut a lot of this bar and also trip the sedan light surrounds a little to make it all fit. Here is a few pictures i took last night once piecing it all back together. Poor quality pics due to shit phone, poor garage lighting and 10pm at night
Looks good Scottie.
Can you place the number plate on the center of the front instead of where it is?
Would certainly give more flow and look more aggressive :)
Plates only resting there at the moment, holes in plates didn't automatically line up so I just need to give it a quick drill
Love the look of the four door front bar mate, having the FMIC piping just peeking through looks tough as. :thumbsup:
Thanks mate. I'm really chuffed with the way the bar has turned out so far
says the man who screwed speakers on the outside of his door trims :P
looking good scott, much angrier than the old front bar.
I also drilled my number plate to my front bar, but what I'm getting at is brackets would look better
Thanks for the comments guys. I think for now ill just screw the plate into the front bar. Can always change it later on. Going to paint my wheels with the semi's on black so i look less like a commo when there are photos of my car floating around with two different pairs of wheels on
I'll do you a good deal with tyres ;) I won't need em since my big f'off wheels will be going on :D
Cant wait to see your big ass wheels on....
Also I hope you're not trying to offload the C-Ultra's from your sig onto me...lol
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
