I've got he HPX all round on the the wrx, very happy with them, good cold stopping abilities and seem to handle some good hard street stops.
Will be doing to the a1rm on the skyline when its ready to come back out to play
  • Replies 14.2k
front page of the australian.
THE navy's $6 billion Collins-class submarines face serious operational restrictions after being hit by a run of crippling mechanical problems and troubling maintenance issues.
ok so we need some help guys, whats the biggest turbo hks make? anychance there is a RB30,000 kit?
according to the australian our swedish engine is no good :) musta been the boost controller i installed and upped it to 400psi
Edited by Inline 6
try ebay..or racespec..same thing :)
Well had my first run in with SAPOL in the GTR today. Got pulled up on Fletcher Rd by one of these but a little older. Had surf boards and all on the roof racks and even a "UNIT' sticker. Pulled me up because I wasn't the registered owner of the car (but I had changed it yesterday). Let me go with "Just be careful for me mate"
Did it have police insignia and sirens? With surfboards? Dude show u his ID ?
-D
Yeah Dohmar. He even showed me the screen saying it was still registered in the old owners name. I didn't even believe it. I even said to him "man thats sneaky as" he just laughed and replied with a "We gotta keep you young ones on your toes"
YAY ABE IS HAPPY :ermm::blink:
Got my car back today, runs like a dream. It is now making 265rwkw @ 15psi and 2 degrees extra timing. Full boost is seen at about 3.5k-4k, it is a little laggy for my taste but means i cant exactly mess around as much, so fuel economy should also be good too. However, once boost kicks in....you know it :( .
Whats it got;
Nismo 740cc Injectors
Garrett GT3076R (3037S) with 3" Front/Dump and 3" Magnaflow Hi Flow Cat.
Haltech E11V2
Turbotech Boost T
NGK Iriway7 Sparkplugs
Superspark Coil Packs
Also had the timing belt and accessory belts changed as well as the belt tensioner and spring, oil, oil & fuel filter changed, water pump and seal changed, also the front crank oil seals too.
Dyno Sheet
Edited by Aberax
Whats it got;
Haltech E11V2
Turbotech Boost T
Dyno Sheet
Excellent result... those Haltechs are a serious piece of kit
Makes me wish I had my turbos already, I have got some siemens-deka racing injectors on their way but only 575... I won't ever be needing bigger while the car has N1's...
(and the injectors cost $360 aussie from the US, and that includes shipping. i love the near-parity... great time to buy from the US..)
soon as they arrive, I'm gonna buy some isc camgears and have my mechanic tune it all
-D
nice power curve u got there mate
did u get a print out of the air/fuel ratios??????
I am a bit of a noob when reading Dyno Graphs...but i believe it is the dotted line on the graph i posted. I think it starts off at about 13:1 and then goes to about 11:1 towards 7000rpm.
Edited by Aberax
that looks like some kinda ratio AFR:P, so what is P ??!?!? becuase its all over the place as far as a straight /normal AFR map goes...
I don't think the AFR's are supposed to be too linear.
Anyway, for comparison, here are the Dyno sheets from earlier in the year when the car was more "stockish"
Power/AFR
Power/Boost
And maybe later i may post pictures of my engine bay.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
