  • Replies 14.2k
Have you looked at the hi octane sumps? They look like a serious bit of kit and will be what I go for when I build my motor. Some nice internal gating/baffling too
+1 for high octaine sump!! and yeah, needs a bit of cut and wleding
as far as the tomei sump baffel goes i think its either place or screw fit
yeah thats a shame matty fire takes no prisoners or no prejudices
indeed steve, hardest luck story was from the first photo. The guy who lived there lost his first house in the "white flat" fire 2 years ago. his son built the house for him so he had somewhere to live, and he's copped it again. He said to one of the guys i was working with "they sell houseboats on the murray yeah? might be time for me to buy one of them!"
Whats that thingamajig?
-D
thats a "rural padmount" ground level transformer. only uses one phase from the 11kv system (the one cable coming into the "elbow" on the left). Produces 2 phases of 240v for consumer supply. This one WAS feeding 4 houses, but only 2 were left that could be safely re-energised by generators. Note, that was closed during the fire and normal operation, so shows how much heat there would have been
Hope everyone has/or is having a good xmas,
Can anyone recommend a good place to get guards rolled? My tyres seem to like scraping the guards now...
Edited by skwiz
I need some help. I think I've got an inlet leak.
If I rev the engine up and release the throttle , it stalls. But if I take it easy it's fine :P
I'm thinking it's the inlet manifold gasket ?
Any ideas on how to be sure ?
Lose the hektik flutter.... :D
Luke ENR34 is the man to see for guard rolling :D
any idea on prices?
only because i am too lazy to call them.
youre far too lazy for your own good jake.
About $90 a guard, give Luke a pm first mate
what you smoking james? i want some.
bleh, $90 a guard? jesus.
its only $40 a guard for ns members.
ill have to get my guards re-rolled for the cst's, might just get all type to do it.
Edited by scandyflick
I've heard someone say that 98 Octane fuels offered by the different petrol station brands are different in their makeup, and apparently BP ultimate is the better one to use. Is this true or a load of waffle? Does it really matter if someone uses V Power or BP Ultimate or Vortex 98?
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
