  • Replies 14.2k
Have you looked at the hi octane sumps? They look like a serious bit of kit and will be what I go for when I build my motor. Some nice internal gating/baffling too
+1 for high octaine sump!! and yeah, needs a bit of cut and wleding
as far as the tomei sump baffel goes i think its either place or screw fit
yeah thats a shame matty fire takes no prisoners or no prejudices
indeed steve, hardest luck story was from the first photo. The guy who lived there lost his first house in the "white flat" fire 2 years ago. his son built the house for him so he had somewhere to live, and he's copped it again. He said to one of the guys i was working with "they sell houseboats on the murray yeah? might be time for me to buy one of them!"
Whats that thingamajig?
-D
thats a "rural padmount" ground level transformer. only uses one phase from the 11kv system (the one cable coming into the "elbow" on the left). Produces 2 phases of 240v for consumer supply. This one WAS feeding 4 houses, but only 2 were left that could be safely re-energised by generators. Note, that was closed during the fire and normal operation, so shows how much heat there would have been
Hope everyone has/or is having a good xmas,
Can anyone recommend a good place to get guards rolled? My tyres seem to like scraping the guards now...
Edited by skwiz
I need some help. I think I've got an inlet leak.
If I rev the engine up and release the throttle , it stalls. But if I take it easy it's fine :P
I'm thinking it's the inlet manifold gasket ?
Any ideas on how to be sure ?
Lose the hektik flutter.... :D
Luke ENR34 is the man to see for guard rolling :D
any idea on prices?
only because i am too lazy to call them.
youre far too lazy for your own good jake.
About $90 a guard, give Luke a pm first mate
what you smoking james? i want some.
bleh, $90 a guard? jesus.
its only $40 a guard for ns members.
ill have to get my guards re-rolled for the cst's, might just get all type to do it.
Edited by scandyflick
I've heard someone say that 98 Octane fuels offered by the different petrol station brands are different in their makeup, and apparently BP ultimate is the better one to use. Is this true or a load of waffle? Does it really matter if someone uses V Power or BP Ultimate or Vortex 98?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
