  • Replies 14.2k
Not sure how many soccer fans are on this board but it was nice to watch Adelaide United win the first game of the Asian Champions League last night.
Despite finishing bottom of the A-League they won their last two games and now have 3 wins in a row to build some momentum to take OS. The team looks better too with the new signings.
GO REDS!
well boys and girls i have just made my lunch it consists of a ceaser salad mix from the super market an avocado cherry tomartos mushrooms and a fresh roast chicken all mixed together for a drink its apple and mango juice made by mountain fresh and for a snck passionfruit yoghurt from the yoghurt shop yuumm
yer Ive got a chicken caesar here to eat today too.
cheap food for a day
paid for the missus to have a holiday. so I thought bugger it, i need a power-fc
bought one from ebay for $690 incl hand controller for the rb26dett, including a tune from JUN (stage 1).
thats the last thing i needed for the r32 sedan.
just got to chop the $1.25 cage up to suit, then tune at boostwerks on 7th april.
must get to it and fit the speedo cable, meh sore too sore :huh: need a hoist
Be careful the tune will be set for 100RON.
yes but did you buy it made or did you make it
your so lovley you paid for her to have a holiday
thats cheap for a power fci remember about 3 years ago when pfc's were not around and i was working at auto barn sitting on ebay trying to buy one for a customer at 1500
I had an et turbo .
Between blowing gear boxes and turbos and every other f**king thing on the car up, they arent bad.
Money pits. Non turbo might be the go tho?
http://www.pulsarparts.com.au/Default.asp
Honestly man. I spent alot more on that ET turbo than I have on my 34.
Shit goes wrong with them. cursed.
Old turbo cars = big trouble.
I went through 2 gearboxes, which aren't cheap.
2 turbos, which also weren't cheap at the time.
went through regency about 3 times with it.
Shit falls apart on them.
Cursed I tell you.
couple pics
Matty got another tow for you my friend.....
PM sent
GO REDS!
that was an own goal wasnt it.....but i think Lachie claimed it....good to see them off to a good start.....just a pity that Arsenal lost their game to porto.....good thing it was an away game for us.....
Well i had mongolian lamb with fried rice......very very good from a little chinese place and the price for all under $12 gotta love it...and for the drink was a iced tea yumm....followed by a cancer stick :huh:
I need a half decent daily lol :huh:
then don't buy a ET, they fall apart as steve said
buy a R31 , cheap, use the RB30 someday, parts from wreckers easy to find, etc
mine has over 500,000k on a unopened engine, head seeps a bit of coolant but still idles better then the R34...lol
I need a half decent daily lol :O
might be selling my r31 s3 exe. 1989, first regod in 1990, white very very good condition for the age.
brand new: xtreme hd clutch, radiator, water pump/pulley, belts, full exhaust, manual conversion (second hand obviously) and few more brand new parts. have receipts for over 3K in just brand new parts.
+ got full pioneer speakers all round, jvd cd/mp3 deck n more shiz.
also at the right price will throw in a brand new "nismo" pack lol including: brand new nismo steering wheel, gearknob, pedals, bucket seat and seat covers ;)
:D
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
