I am soooooooooooooooooooooooooohooooooooooooooooooooohooooooooooooooooooo fkn sore from sunburn today it is unbelievable. Lucky I shuffled all my work to tomorrow and am spending my day home in my jocks in front the the PC/TV :)
  • Replies 14.2k
I am soooooooooooooooooooooooooohooooooooooooooooooooohooooooooooooooooooo fkn sore from sunburn today it is unbelievable. Lucky I shuffled all my work to tomorrow and am spending my day home in my jocks in front the the PC/TV :down:
hahaha, im wishing i took a hat... the top of my head got thrashed in the sun.
the joys of being a ranga
another redskin!
Chief Bezender was working as an indian tour guide on the navajo reservation
He was taking some tourists around the plains when he suddenly put his ear to the ground.
"Buffalo Come." he said. "Wow thats amazing, how can you tell?" said the tourists
"Ground Sticky."
-D
Without having seen it..... Have you done a continuity test between ground and the high beam 'on' switch?
nah, but i havent touched any of that wiring whilst removing the others, which is odd :S
meh, will look at it later on in the week, got the truck home tonight instead of my truck LOL
JMW's car sounded awesome when he took off haha
Thanks man, was good to meet you mate.
ME.
and James :down:
Extremely burnt neck and face
i recon james is really burnt his neck blended in to his red nissan shirt lol
Already going a nice dark shade of brown :P
Seems friday i might go see Vince and compare dyno sheets, possibly could be in for a few surprises!
Is odd but sounds like a short to ground. If you need to borrow a multimeter let me know
Go to Japan Luke. Travel while you are young, before you are tied down. I did a fair bit of travelling in my youth, but wish I had done much more! Once you get older and kids come along the costs absolutely skyrocket up, and the fun skyrockets down :down:
Of course lots of other things make up for it, but my point is travel while you can be freeeeeeeeee
anyone know were to get defi gauge sensors?
need some like yesterday!?
anyone know?
also dale if you read this or anyone else,
i wanna put my afm between plenum and cooler, coz my intake pipe is too big to fit it, will this be better as it wont have air recirculating?
anyone know?
you cant do that as the air in that section is compressed by the turbo, which means its temperature is different from ambient, and it cant calculate the volume properly. afm's must be before the turbo.
-D
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
