  • Replies 14.2k
yeah 044 is external, the nismo ones i've seen for >600 so they're out. 33 GTR pump will drop straight in but i'm expecting Nissan to give some sort of shit pricing.
What trouble did you have with the 040 Abe? Hardest part of the install looks like positioning it close enough to the bottom of the tank.
Edited by nicr4wks
sscond hand gtr pumps go for $100-$200, modify the cradle a bit, and youre sweet. can buy brand new walbro pumps for about $160 from ats, basically the same to fit as gtr pumps, minimal mods and it goes right in.
Edited by scandyflick
Yep I highly recommend the Walbro 255lph - had one in my S15 and my R34. The 040 I had in the S15 sucked up silt off the bottom of the tank and blocked, then failed.
Pumps with socks (like the stock pump and the Walbro) are better designed for Nissans IMHO.
Also, got camber? I have some camber arms ordered to address the problem, but it looks pretty slammed at the moment :D
haha ill take this stagea anyday!!!! http://www.discountusedcars.com.au/used-ca...ea/3483209.aspx
lol someone didnt get enough sleep! or am i misinformed haha
hahaaha at least its an autech
Anyone know roughly what a 33 GTR fuel pump is worth? Or should I just drop in a 040.
i have an 040 was already modded to the cradle so i just dropped in :D
hahah nice Andrew
i go to AutoPerfection tomorrow to have my splits fitted, any one have questions
alarms, installs, tints, what colour undies to wear :D
shit balls. thats crazy.
are you feeling the blue or the beige? im leaning towards the blue at the moment.
getting them to fit is f**king simple if you have a dremel and hose clamp. i was a bit confused when i did mine, but then i looked at went "ooooooh", 30 minutes later it was in the tank.
+1
i rate the walbros, very simple to install, and they do their job well. there's a lot of mixed opinions around other areas of the forum on these, but we chose it over the bosch for its similarities to the std setup. installed, tested, and proven good performer.
fuel pumps arent hard to install if your not afraid of modifying the cradle, getting a few cuts on your hands from the fiddly bits around accessing the tank, and of course inhaling petrol fumes :D
some like to go that bit further and rewire for better voltage
would look even better with some 25mm spacers ;D
only concern I'd have with the wallbro pump is whether or not it flows more than the stock gtr pump - i know this isnt much of an issue till u go over 300kw but I'm leaning towards the nismo (125% flow rate) rather than a bosch
what splits are u getting steve? type R's ?
-D
the stag has had an 040 for 4 yrs now, no issues.
the rb26 sedan has an intank gtr pump and fitting an external walbro 305lph unit - $160 good price
040's are around 190 but you can get copies for around 100
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
