  • Replies 14.2k
so... anyone out my way care to play taxi for an hour or so tomorrow? got a few things i need to pick up for the s14.
yeah mate I have some time tomorrow arvo if you need a chauffeur - I prolly owe u a favour or 2 anyway. Can be at your place around 12pm if u like?
woo! got my fog lights! couple fuses, a relay, a switch, and some wiring and itll be good to go. should have my front bar by tomorrow as well. rad.
lol. wired the lights in. piss easy. just need a switch now.
thatd be awesome if you could. cheers.
Edited by scandyflick
