I despise itunes how hard is it to put music onto what is essential an overrated USB drive? My wifes $100 music player is easier to use then anything apple produces
I don't understand how telling ITunes "this is the directory my music is in, now add it all to the library" is hard? I think it is awesome.
And I was more talking about the App Store than ITunes .... anyone over 15 and has a half decent car stereo rarely listens uses their IPhone for music anyhow IMHO.
  • Replies 14.2k
That would be sweet man. Might have to see if matty can drop it down.
Anyone else have trouble writing in the reply box on their iphone? I touch the box to type and it does nothing, use to work fine when i first got the phone
Edited by DSTROY
I dont have any troubles. Maybe try clearing the internet cache? (Settings -> Safari -> Clear Cache)
Fu*k yeh. ARC cooler with hard piping kit just arrived. Has HKS silicon hoses and a greddy intercooler pipe.
Jake like this. Putting the casino winnings to good use i see?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
