spotted: ECR 33T this morning on windsor rd near baulkham hills....
sam the new rims look awesome.......
werent you going to go wakefield today ?
New rims?!? I demand pics Sam! hehe :P
My white r33 seems to have stealth mode turned on too. How do I turn it off?
wil..
New rims?!?  I demand pics Sam! hehe :(
wil..
its an irreversable option on some '33s.... :D
yellow personalised plates :D
I'm in FA :(
I always park in the multideck.
wil..
i try to park wherever i can find parking aslong as it's covered.. i used to park outside with the other red r33 s2 and a black gtr.. but the threat of hail scared me.. there's always a nice silver supra parked on level 4/5.. but i dont get why the foglights are covering the fmic air intake...
Pete
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
