Hey Shonen if you want a good price on a top quality job call Louie at Xclusive colours (02) 9681 1162
thanks duncun....ill see how bad the front bar gets....got soo many stone chips...
sorry for my late reply....but i cant seem to log on to sau at home anymore !!!!
i dont know why....but SOMETIMES it works but most of the times it says it cant find the site.... :D
sorry shonen, you've been banned for whoring all the time
:D
BTW I spotted you Gizmo73 at lunch in North Ryde the time before last - you just need to get out to more events :)
Spotted GTR 33R at Shell in West ryde few hours ago
that was me mate , i didnt see you , what were you driving ? i was i a hurry and a bommodore almost reversed in to me .
i fill her up there quite often .
I was on victoria road, blue lancer so I duobt you would have noticed me.. I was sitting there drooling at your car while waiting for the lights to change :)
I used to work at that maccas and lived down the road till friday so used to be there all the time first time I've seen ur car there though
but since I missed it today :wavey: now lol
you are right i didnt see you , i was probably inside paying for the fuel .
I never get spotted as well. :)
I spot on average about 6 R33's everyday on epping rd. I get snobbed because im a 32. Dam racists! hahaha j/k
Spotted Sean (FLAPS) in Burger King at Northmead a few months back. Even sat down and had lunch with him. Wasn't driving his car tho...
You must rack up some decent kms!
Yep sure do - about 650kms per week !! :Oops:
the car loves it though...
Hey Duncan..
Was it the car you spotted, or was it me ??
If it was me at a lunch venue we all know, shouldve dropped in for a round !!
hmm...speaking of which we need another lunch...
Spotted a shiney black R33 with a green Pull-me-over-plate stuck to the back boosting hard past Shell on Old Northern Road, heading towards Galston. I was in the Shell...not getting spotted (again)... LOL
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
