i think i spotted mona.. penno rd 6:30ish
saw her head turn to look thru the truck i was going past in the other lane
:) i think that was me!!! are your plates yex something?! i thought it might have been you!!! figured you'd be one of the few r34s in this area :)
also spotted a teal r33 - fob something, a black r32 on kissingpoint rd near dundas... the two occupants were being blinded by the sun!! plus another gray 33 near carlingford court! :)
:P i think that was me!!!  are your plates yex something?!  i thought it might have been you!!!  figured you'd be one of the few r34s in this area :(
also spotted a teal r33 - fob something, a black r32 on kissingpoint rd near dundas... the two occupants were being blinded by the sun!!  plus another gray 33 near carlingford court! ;)
yes t'was me... i wasn't sure it was you.. but like you said.. only a few silver r33's with a chick driving around that area..
]']i saw a R33 GTST S2 white
with the plates UCMOON
and a R34 GTT red 1 out side the commonwealth bank off power road.
yeah who owns UCMOON now? It lived near me until it was sold, now I don't get the pleasure of driving past it every morning!
Just spotted a white R34 GTR M-Spec travelling in the opposite direction to me on Fullers Road in North Ryde around lunchtime. (Im the guy driving the Black R34 GTR)
Very nice car mate - hope you visit the forums - sorry I didnt wave back but I didnt see you until the last moment. I also saw you parked it there for a second a bit earlier (when i was going out to lunch) and slowed down for a look. I feel so bad for violating the code!
Anyway if you do read this PM me id love to check out the M-Spec some day :P
Spotted: BLACK R34 plates MOSTRO or something like that....pretty sure it was a GTR..only had a quick glance. This was near PowerPlay tuesday.
Also spotted today Duncan in HGE-002 at the corner of victoria rd and devlin rd...with the OUCH sticker on the side....hahaha cracked up hard when i saw that....
I was beeping my horn and waving a like a lunatic to grab your attention... :)
Well it was either you Mona or sum other hot chick driving a silver R33 then
hahahaha
:aroused:
lol!!!! it definitely wasn't me then!!! :)
spotted a white r34 gtt in the city... plates GTT 888
and a dark 33 in the superdome carpark.. plates arb something...
GO THE RAZORS!!!!! :)
spotted a balck 33 in QFCL building, parked next to it to go work, but got kicked out cos i wasnt allowed to park there.....sooo then i parked outside and there happend to be another black 33 with fmic and gtr wing...had to park next to it,.!!park with style!~
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
