not seriously, it has a stock box in it.... at the first drag wombat it ran an 11.9 so he was sent home due to the lack od ANDRA lisence... Peter doesnt care for driving fast in a straight line, he is more of a circuit racer than a drag racer.....
the vehicle was built as a promotional vehicle for his business..... the motor in it was built by Peter personally but actually came out of his old R32 race car he had back in NZ. Rather than build something new, he freshened it up back in 98 and put it in GRACER :):P
Spotted a veeerrrryyyy nice looking r33 gts-25t at campbeltown today, which is saying something as i'm not a fan of the r33 shape.
Dark orange, very low on dark grey 18's with a nice rear bar and skirts, couldn,t see the front. It also had the rear wing replaced with one of the small lip ones that sits flush with the top of the rear guards.
Very impressive.
wilch spotted the old hge 1 I think.
I spotted 3x R31 2 doors, 1x R32 gtst, 2x R33 gtsts, RONIN, SLO200 and Steve's 350z racing at Bathurst on the weekend. Not to mention the local boys Nick and Bill with the 33 gtst and 34 gtt.
Anyone have pics/more info on GTRRRR?
just a neat clean black R32 with some rims and coil overs.... Mike is a member here and may have some pics of the car he wishes to post up as i can never remember where they are to link them....
at about 10:30-11 tonight, spotted a dark 33 with a huge rear wing on blaxland rd, heading towards lane cove road.. i was heading towards epping... hehe.. we passed each other in the dark... i thought it was a 33, but i wasn't 100% till i saw the familiar tail lights.. by then it was too late to wave.. so :wavey: now :D
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
