oohh.. i got mentioned :headspin:
hahahaha. i agree about the washing
washed my car the night before... by the time i got to bathurst, i had half the insect population stuck on my bonnet ...
agreed on the nice cars there though =)
was a great day
p.s did anyone think my exhaust was a bit too loud? i think it might be but i dont really know how it sounds outside the cabin.. any input guys?
Who is the guy I see driving around in a black R34 GTR around Chatswood? usually see him buzzing up and down Fullers Road off the Pac. Highway?
HAQ-666 plates. Saw him on that same road a couple of weeks ago. Must be his favourite road :rofl:
that was such a nice line up of cars!!!! hehe... a car off between the 33s and 34s! :rofl:
yes i see how your nick is spelt r34eddie ;) and thanks for the intro!!! i had to force it from you!!! i spent half the trip wondering if i'd met you before!! lol! and thanks for the cd as well! :rant: i've been trying to find romeo and juilet by dire straits for agggeessss!!!!! :rant:
keep spotting black 32 gts-t w/ big wing driven buy a cute p plater (girl not guy!) round the hills area. mmmmmm.......cute girl driving skyline :drooling:
where exactly in the hills. chick in performance car = :drooling: :aroused: :drooling: :aroused: :drooling:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
