I was thinking it may have been but with the hat and shades i couldnt tell.... actually i couldnt tell even without the hat and shades....
Who would have thought.... the day after we both make note to stop each other.... we do.
Can u let me know the detail about yr boot tho. did u do it or did u get it like that. If you did it or got it done can u tell me how/who?
yeah I know ay??? so you were stalking me?
i found out that light was green after i bought the car! Your more than welcome tocome check out my green bum...but I'll tell you what? Trade an S1 secret for an s1 secret?
PM SENT!
PM SENT!
Stalking??? i dont know if i'd call sitting out side your house all night with a telephoto lense stalking..... but if it floats yr boat :)
Spotted a white GTST in epping last night in the coles car park... didnt get the plates but it had a red sticker on the rear bar of some kind
black 32 gtr... i was turning left onto new line... you (if it was you :D ) were stopped at the lights to turn right...
that was me :) hehe
nice 32 there :), I laughed when the riced up corolla P plater slowed all the way down to let in your sexy line ;):)
Spotted a purple 33 gtr (could have been a GTST) in a bad way before david road along newline rd. was hanging over into the gutter with the front end shortened.
Didnt get chance to get the plates
Anyone feel like claiming it?
Okie doke lets see.
Sat morning gunmetal grey 33 on berowra waters road...thought it was Messiah??? but I got no wave back???
Last night...about.....6....black 33 with a nice shiny front mount on the front....no idea where I was...think maybe new line road??? or boundary road in cherrybook??? got a very cool nod before he showed off around the corner....lol...but thats ok coz I did the same boosting away up the street
Very nice white 33 on pacific highway at chatswood this morning too..nice car man!
that is all
Okie doke lets see.
that is all
T'wasnt i! i'm giving the line a little rest on the weekends until it gets tuned....
its no fun i swear. and check yr PM's.
Spotted a Silver R32 Gts-t on Merrylands Rd turning into the Red Rooster car park. Was this afternoon at about 4pm. Had standard black on yellow plates and silver mesh wheels.
A few minutes later, an egg yellow R33 GTS-t with GT-R kit.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
