spotted: RELODE white R33 GTR with one yellow racing stripe on the left side of the car in front of world tower at around 2am this morning.
I also spotted RELODE on Sat night driving down George St at around 12.30am...I thought the car looked familiar (goes diggin through old SPEED mags)
spotted a black r32 gtst (no not mine!) headin south on gladesville bridge bout 2:30pm last friday the 15th. Now i have a real sharp eye for spotting gtr look-a-likes, hey, i drive one! but this one i really had to look twice, dumped reeeeally low, no spolier - but a gtst bonnet. number plate ybk...
and headin south on warringh fwy just past falcon st about 630pm i spotted a nice white r34GTT number plate AB.... (not abobob) - had gold 17's...
yesterday: red r34 drivin past gymea shopping village (it was dark, couldnt see much of the car other than the tail lights)
r33 parked in chinatown
saturday: white r34 gtt in town hall george st, silver r33, black r32 along lane cove road whilst i was waiting for a bus
Spotted White R33 GTST with shopping list on door, black R33 GTST, Black R33 GTR with leather trim interior and Liz all on Pacific HW this morning
and I saw you again on Epping road this arvo at about 6...i was going so slow waiting for you to catch up but by the time you finally put your slow arse in to gear you turned off along with the silver 33 with the nasty little man who didn't wave at me in it.
Spotted grey R33 with chrome wheels on Maroubra, Monday around 11pm, twice, inside Pacific Square car park and then when entering a garage in Anzac Pde, still in Maroubra area.. But not sure whether it's the same car or not.., but both were very similar.. :rofl:
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
