I saw and waved at a White R34 GTT on Old Windsor Road (at the lights at the end of the M2)... he gave me a toot back :rolleyes:
Nope, Silver, mine is dark green...
I saw one last Monday (6 days ago) at BP Seven Hills... had an exhaust and sounded nice :P
Was that you??
I saw and waved at a White R34 GTT on Old Windsor Road (at the lights at the end of the M2)... he gave me a toot back :P
I saw one last Monday (6 days ago) at BP Seven Hills... had an exhaust and sounded nice :D
Was that you??
Hey TommO,
yeah, if it was the BP on Abbott Rd, that was probably me! And I've just put the SAU stickers on the front and rear windscreens, too. Fueled up there last night too.
What were you in that night?
Cheers,
Nick T.
Hey TommO,
Cheers,
Nick T.
Thought it would have been - I was eating with a few mates at Maccas, and we were all listening and suprised when we heard your car was manual :D And then we talked about Stageas for a while :)
I'll come up and say hi if I see you there again :)
See, you've been spotted :P
spotted BKLEUP on Castlereagh st. on Sat night, very nice zorst note mate. Also spotted white R33 going opposite direction at Gouldburn st at Wolrd Square, gave a flash and got a thumbs up back  :blink:
hey mate, yeh i think thats was me, do you drive a (i think its called) midnight blue series II? if so then it was me on goulbourn street, nice ride!!!
haha no dude, mine is black but it could look blue probly coz I didnt give it a good wash :lol: . First I thought you should have similar mods to mine until I read your sig, hehe I would have no chance.
LOL, yeh ive got some power behind me, but the car looks like a sleeper hehehe.....
Spotted a silver R-33 GT-R coming off the railway bridge in Toongabbie this afternoon, number plates possibly GTR-100, at around 5.30pm. He/she gave it a little stab as they headed towards the lights near the station.
spotted a nice R33 GTST on the GW near stmarys thiink hes forum name was sicko nice car mate was in a hurry to get home for lunch or i would have followed for longer
Edited by blk180
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
