Saw Flukey in his 32 on silverwater road @ auburn :D
Had a bit of fun :(
hahahha :( sounds good man sounds good where were you off too saw u chuck a u at auburn man
Spotted a white R33 GTS-T (S1?) on Aiken road yesterday. Seen it a few times. Nismo sticker on the rear quater window I think?
Flashed and flash in return...  :)
think i spotted you on homebush bay drve
or another white 33 gtr (i think no badge) with rear pods
Yeah that was probably me.. I drive through there a fair bit. What day was it?
hahahha :P sounds good man sounds good where were you off too saw u chuck a u at auburn man
I wasnt sure how to get to rydalmere. had to get to one of my computer hardware wholesalers. But yeh, it was good fun. Nice of you to keep up with me ;) I dont like speeding but if its with another line to have some fun then why not (:P)
Hope to see you around sometime soon ?
Sorry about all the black smoke:p car aint tuned properly yet, and i was playing around with ignition timing a bit :)
I think I spotted Primordial in my mirrors this morning as I was about to head across to Coonara Ave.
Ya I saw you there! Is your car running ok at the moment? There seemed to be an odd high pitched clicking sound coming out when you boosted it over the hill??
Either that or my ears hadn't woken up properly yet (which is probably the case! haha)
i've said it before and Ill say it again - love the dish :P
My car's running fine... :lol:
I hit the rev limiter by accident :P
...that and my wastegate opened. :(
...that and my wastegate opened. :P
LoL.. That would make sense then! Hehe.. oops! :lol:
spotted MARSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!
today out in albion park!!!!
Hahahahah! nice to see ya bruvaaaaaaaaaaaaaaa!!! We'd just been in a 300zx cruise to Kiama and were heading home
Saw MAD GTR this afternoon turning off the M2 at Windsor Rd. Earlier at that Shell servo, Ruchcutters bay where that GTP 350Z always is, there was a silver coupe V35! Definitely had an 'infiniti' badge on the back of it..No number plates either
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
    • To drain the Intake Heat Exchanger, there is a crappy drain plug in front of the driver's side front tyre: You should use the largest headed phillips screwdriver you had, and in my case I needed vice grips on the hose above as the plug was tight (tighter than it needed to be, since it has an o-ring seal).  After you have a tray down and open the drain, open the intake heat exchanger reservoir cap (drivers side one) and you should get a couple of litres of coolant To get to the radiator, you need to remove the plastic engine undertray. It is held on with a series of 10mm headed bolts and some clips. For the radiator, there is another type of crappy drain (kind of like a plastic banjo bolt) and you should attach a length of hose to direct the stream of coolant per this pic (otherwise the coolant hits the rad support and goes everywhere). The drain is on the rear of the radiator on the driver's side and a bit hard to find. Put a big tray or bucket down (5l won't be enough) and slowly unscrew the fitting by hand. You only want to remove it far enough for coolant to flow, it you unscrew it right out the whole fitting and direction pipe will come off and you will get a coolant bath (yum!). Undo the radiator reservoir cap and it should empty about 8l
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You also need to drain the intake heat exchanger to remove the radiator so you will need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. 2 other tools that really help dealing with coolant lines and spring clamps are Bent Needle Nose pliers Hose pliers Between them they will reduce the frustration (and injury) potential by about 1000% Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
