Saw Flukey in his 32 on silverwater road @ auburn :D
Had a bit of fun :(
hahahha :( sounds good man sounds good where were you off too saw u chuck a u at auburn man
Spotted a white R33 GTS-T (S1?) on Aiken road yesterday. Seen it a few times. Nismo sticker on the rear quater window I think?
Flashed and flash in return...  :)
think i spotted you on homebush bay drve
or another white 33 gtr (i think no badge) with rear pods
Yeah that was probably me.. I drive through there a fair bit. What day was it?
hahahha :P sounds good man sounds good where were you off too saw u chuck a u at auburn man
I wasnt sure how to get to rydalmere. had to get to one of my computer hardware wholesalers. But yeh, it was good fun. Nice of you to keep up with me ;) I dont like speeding but if its with another line to have some fun then why not (:P)
Hope to see you around sometime soon ?
Sorry about all the black smoke:p car aint tuned properly yet, and i was playing around with ignition timing a bit :)
I think I spotted Primordial in my mirrors this morning as I was about to head across to Coonara Ave.
Ya I saw you there! Is your car running ok at the moment? There seemed to be an odd high pitched clicking sound coming out when you boosted it over the hill??
Either that or my ears hadn't woken up properly yet (which is probably the case! haha)
i've said it before and Ill say it again - love the dish :P
My car's running fine... :lol:
I hit the rev limiter by accident :P
...that and my wastegate opened. :(
...that and my wastegate opened. :P
LoL.. That would make sense then! Hehe.. oops! :lol:
spotted MARSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!
today out in albion park!!!!
Hahahahah! nice to see ya bruvaaaaaaaaaaaaaaa!!! We'd just been in a 300zx cruise to Kiama and were heading home
Saw MAD GTR this afternoon turning off the M2 at Windsor Rd. Earlier at that Shell servo, Ruchcutters bay where that GTP 350Z always is, there was a silver coupe V35! Definitely had an 'infiniti' badge on the back of it..No number plates either
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
