spotted a white ceffy passing Curl Curl beach last night.
cc?
Hay Liz - I was finally spotted *beam*.
Was trying to have dinner for my bday.. All booked out, ended up goin to Manly. Were you in the r33 with unpainted front bar?
Stuck in in traffic on Walker st North Sydney about 6pm-ish spotted a nice white R33 i think the plates where ATD-37R? with SAU sticker on left rear quarter panel, girl driver. Nice ride.
I was the grumpy $hit in the silver 280zx next to you... :lol:
Edited by Archie@
Oh yeah. This morning about 8am on Warringah Rd.
ARL something r34 - TOUGHEST looking r32 evarr.. Cute lookin driver too :(
AQN something black r34 always see it.
A r31 and r33 too.
4-5pm-ish waved hello to a busy lookin owner of a tough lookin r34 on Warringah Road.
Also spotted SLY 31 a r31 on Link Rd - had a chat.
if it sounds like liz, looks like liz it probably is liz!
Archie!!! I had a feeling it might have been you, I recognised the dent!
Man I was discussing with my mate buying a 280 I've found all afternoon.. and then as soon as i leave work I find myself behind a beautiful 280, it was a sign!!!! I couldn't stop starring...you have such a nice car!
Anyway, decided against buying the 280 for now, I think my parents would kill me if I've brought home a 3rd car!
BTW guys - the green bum is shown only to those special few!
aaahhh.... you noticed the dent :) did you see my fantastic rust proofing job with the fish oil, covered by a bit of electric tape :lol:
Great car the 280, solid block of an engine and plenty of room for an even bigger donk if the need be.... mines in a sore need of a wash though...
Edited by Archie@
aaahhh.... you noticed the dent :P  did you see my fantastic rust proofing job with the fish oil, covered by a bit of electric tape :lol:
hahah, very impressive!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
